RB_SETCOLOR
RB_SETCOLOR new 2079
Top  Previous  Next
Set the color of a LED.
RB_SETCOLOR LEDnr , color()
LEDnr
A word variable or numeric constant which defines the index of the LED. This should be a valid index for the active channel. When the current channel has 8 leds defined with CONFIG RAINBOW, a valid number would be in the range from 0-7. Leds start counting at 0. This is independent of the option base !
color()
A byte array with a minimum length of 3 that holds the RGB information. A LONG or DWORD can be used as well.
The color information is set in memory. To update the color of the LED, use RB_SEND
CONFIG RAINBOW , RB_ADDCOLOR, RB_ANDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
'                   rainbow_ws2812_KnightriderDual.bas
'                      based on sample from Galahat
$Regfile = "m88pdef.dat"
$Crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0
'                                                   ^ connected to pin 0
'                                       ^------------ connected to portB
'                         ^-------------------------- 8 leds on stripe
'              ^------------------------------------- 1 channel
'Global Color-variables
Dim Color(3) as Byte
R alias Color(_base) : G alias Color(_base + 1) : B alias Color(_base + 2)
'CONST
const numLeds=8
'----[MAIN]---------------------------------------------------------------------
Dim n as Byte
RB_SelectChannel 0         ' select first channel
R = 50 : G = 0 : B = 100   ' define a color
RB_SetColor 0 , color(1)   ' update led on the left
RB_SetColor 7 , color(1)   ' update led on the right
RB_Send
  For n = 1 to Numleds/2 - 1
    rb_Shiftright 0 , Numleds/2 'shift to the right
    rb_Shiftleft 4 , Numleds/2   'shift to the left all leds except the last one
    Waitms 100
    RB_Send
    rb_Shiftleft 0 , Numleds/2   'shift to the left all leds except the last one
    rb_Shiftright 4 , Numleds/2 'shift to the right
    Waitms 100
    RB_Send
  waitms 500                   'wait a bit
