Fills the entire memory of the active channel with a specified color
RB_FILLCOLORS Color
Color |
Color is a byte array or variable that contains color information. |
The entire memory of the active channel is filled with the specified color.
This statement will not update the LED's. This means that you need to use RB_SEND to update the LED's. Or use RB_FILL which will update the LED's as well.
CONFIG RAINBOW , RB_ADDCOLOR, RB_ANDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
' rainbow_ws2812_Levelmeter.bas
' This example demonstrate the switching between two Rainbow-Stripes while simulating
' a simple kind of an stereo levelmeter and the use of some RB_statements.
$Regfile = "m88pdef.dat"
$Crystal=8000000
$hwstack=40
$swstack=16
$framesize=32
Config RAINBOW= 2, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0 , RB1_LEN=8, RB1_PORT=PORTB,rb1_pin=1
Dim n as Byte
Dim Color as DWord
Dim CH as Byte
Dim LEFT_Level as Byte , Left_Level_OLD as Byte
Dim Right_Level as Byte , Right_Level_OLD as Byte
Const Channels = 2
Const Backcolor = &H000005
'----[MAIN]---------------------------------------------------------------------
Color = Backcolor
For ch = 0 to Channels -1
Rb_SelectChannel Ch
RB_Fillcolors Color
Rb_SetTableColor 0,0
RB_send
incr n: n = n and &H30 'n counts from 0 to 63
If n = 0 then Gosub Get_Level 'Read signal
'Switch channel
toggle Ch
Rb_SelectChannel Ch
Waitms 40
If ch = 0 then 'Channel 0
If left_level_old < left_level then
incr Left_level_old
ElseIf Left_level_old > Left_level then
Decr Left_level_old
End if
RB_Fillcolors Color
Rb_SetTableColor Left_level_old ,0
Else 'Channel 1
If right_level_old < right_level then
incr right_level_old
ElseIf right_level_old > right_level then
Decr right_level_old
End if
RB_Fillcolors Color
Rb_SetTableColor right_level_old ,0
end if
RB_Send
Get_Level:
Left_Level = rnd(7)
Right_Level = rnd(7)
Rainbow_Colors:
Data 100,50,0 'orange
