Fills the memory of the active channel with a color and updates the LED's.
RB_FILL Color
Color |
Color is a byte array or variable that contains color information. |
All LED's of the active channel will be set to the specified color in memory. This statement will also update the LED's so it is not needed to use RB_SEND.
This statement is similar to RB_CLEARCOLORS except that you can provide a color and that it is not required to use RB_SEND
CONFIG RAINBOW , RB_ADDCOLOR, RB_ANDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
