Changes the defined output pin at run time
RB_CHANGEPIN Port , Pin
| Port | A numeric variable or constant with the I/O address of the port. Notice that this is an absolute memory address. For ports in the normal IO range, you need to add a value of &H20 to the address.
 Example : Const nprt=varptr(portb) + &H20 Rb_ChangePIN nprt, 1 |
| Led | A numeric variable or constant with the pin number in the range from 0-7 |
When you want to use multiple stripes with the same color, it would require CONFIG RAINBOW to set up all these stripes.
But each configured pin will use memory for the RGB information. When you change the pin at run time, you will use the color information of one stripe.
CONFIG RAINBOW , RB_ADDCOLOR, RB_ANDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
'                   rainbow_ws2812_Demo.bas
$Regfile = "m88pdef.dat"
$Crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0
'                                                   ^ connected to pin 0
'                                       ^------------ connected to portB
'                         ^-------------------------- 8 leds on stripe
'              ^------------------------------------- 1 channel
'Global Color-variables
Dim Color(3) as Byte
R alias Color(_base) : G alias Color(_base + 1) : B alias Color(_base + 2)
'CONST
const numLeds=8
'----[MAIN]---------------------------------------------------------------------
Dim n as Byte, state as Byte, tel as Byte
state=0 : tel=0
RB_SelectChannel 0          ' select first channel
R = 50 : G = 0 : B = 100    ' define a color
RB_SetColor 0 , color(1)    ' update led on the left
RB_SetColor 7 , color(1)    ' update led on the right
RB_Send
   For n = 1 to Numleds/2 - 1
      rb_Shiftright 0 , Numleds/2  'shift to the right
      rb_Shiftleft 4 , Numleds/2   'shift to the left all leds except the last one
      Waitms 100
      RB_Send
      rb_Shiftleft 0 , Numleds/2   'shift to the left all leds except the last one
      rb_Shiftright 4 , Numleds/2  'shift to the right
      Waitms 100
      RB_Send
   'waitms 500                    'wait a bit
   select case state
      case 0 : r=r+5 : Rb_AddColor 0, color(1) : rb_send: tel=tel+1
      case 1:  g=g+5 : Rb_subColor 0, color(1) : rb_send:tel=tel+1
      case 2:  b=b+5 : Rb_orColor 0, color(1) :  rb_send: tel=tel+1
      case 3:  Rb_ClearStripe : tel=4
      case 4:  rb_send : tel=5
      case 5:  Rb_Fill color(1) : tel=5
      case 6:  const nprt=varptr(portb) + &H20 :  Rb_ChangePIN nprt, 1
      case else
        state=0
   end select
   if tel>=2 then
      state=state+1 : tel=0
   end if
