RB_ANDCOLOR
RB_ANDCOLOR new 2079
Top  Previous  Next
Ands specified color info to the specified LED in memory
RB_ANDCOLOR Led , Color
Color
Color is a byte array or variable that contains color information.
Led
The index of the LED number. First LED is 0.
The operation is performed on the memory. An AND operation can clear part of a color. You need to use RB_SEND so that the LED reflects the new color information.
CONFIG RAINBOW , RB_ADDCOLOR, RB_ORCOLOR, RB_SUBCOLOR, RB_CLEARSTRIPE , RB_CLEARCOLORS , RB_FILL , RB_FILLCOLORS , RB_FILLSTRIPE , RB_SELECTCHANNEL, RB_SEND, RB_SETCOLOR , RB_SWAPCOLOR , RB_ROTATELEFT, RB_ROTATERIGHT, RB_SHIFTLEFT, RB_SHIFTRIGHT , RB_CHANGEPIN , RB_SETTABLECOLOR , RB_GETCOLOR , RB_LOOKUPCOLOR , RB_COPY , RB_COLOR
'                   rainbow_ws2812_Demo_Softblink.bas
'This demo show RB_OrColor and RB_AndColor which can be used
'for a flashing LED with a fade effect.
$Regfile = "m88pdef.dat"
$Crystal=8000000
$hwstack=32
$swstack=16
$framesize=32
Config RAINBOW=1, RB0_LEN=8, RB0_PORT=PORTB,rb0_pin=0
'                                                   ^ connected to pin 0
'                                       ^------------ connected to portB
'                         ^-------------------------- 8 leds on stripe
'              ^------------------------------------- 1 channel
Const Numled=8
Dim MASK as Dword
Dim Fade as Byte
'----[MAIN]---------------------------------------------------------------------
RB_SelectChannel 0         ' select first channel
  For Fade = 0 to 7
    Waitms 20
    Shift MASK , left
    Incr MASK
    RB_ORColor 0 , MASK
    RB_Send
  For Fade = 0 to 7
    Waitms 20
    Shift MASK , right
    RB_ANDColor 0 , MASK
    RB_Send
