CONFIG SDA
Top  Previous  Next
Informs the compiler which pin is used as SDA pin for TWI/I2C communication.
CONFIG SDA = pin
Pin
The port pin to which the I2C-SDA line is connected.
When using software emulated TWI, the compiler need to know which pins are used for SDA and SCL.
CONFIG SCL , CONFIG I2CDELAY
CONFIG SDA = PORTB.7  'PORTB.7 is the SDA line
