CONFIG I2CDELAY
Top  Previous  Next
Compiler directive that overrides the internal I2C delay routine.
(Only for Software I2C Routines)
CONFIG I2CDELAY = value
value
A numeric value in the range from 1 to 255.
A higher value means a slower I2C clock.
You may use a value of 0 too but it will result in a value of 256.
For the I2C routines the clock rate is calculated depending on the used crystal. In order to make it work for all I2C devices the slow mode is used. When you have faster I2C devices you can specify a low value.
By default a value of 5 is used. This will give a 200 kHZ clock.
When you specify 10, 10 uS will be used resulting in a 100 KHz clock.
When you use a very low crystal frequency, it is not possible to work with high clock frequencies.
The I2C routines are located in the i2c.lib/i2c.lbx files.
For chips that have hardware TWI, you can use the MasterTWI lib.
CONFIG SCL , CONFIG SDA, Using the I2C protocol
'name                     : i2c.bas
'copyright                : (c) 1995-2020, MCS Electronics
'purpose                  : demo: I2CSEND and I2CRECEIVE
$regfile = "m48def.dat"                                     ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
'We use here the Software I2C Routines
Config Scl = Portb.4
Config Sda = Portb.5
I2cinit
Config I2cdelay = 10                                       '100KHz
Declare Sub Write_eeprom(byval Adres As Byte , Byval Value As Byte)
Declare Sub Read_eeprom(byval Adres As Byte , Value As Byte)
Const Addressw = 174                                       'slave write address
Const Addressr = 175                                       'slave read address
Dim B1 As Byte , Adres As Byte , Value As Byte             'dim byte
Call Write_eeprom(1 , 3)                                   'write value of three to address 1 of EEPROM
Call Read_eeprom(1 , Value) : Print Value                   'read it back
Call Read_eeprom(5 , Value) : Print Value                   'again for address 5
'-------- now write to a PCF8474 I/O expander -------
I2csend &H40 , 255                                         'all outputs high
I2creceive &H40 , B1                                       'retrieve input
Print "Received data " ; B1                                 'print it
Rem Note That The Slaveaddress Is Adjusted Automaticly With I2csend & I2creceive
Rem This Means You Can Specify The Baseaddress Of The Chip.
'sample of writing a byte to EEPROM AT2404
  I2cstart                                               'start condition
  I2cwbyte Addressw                                       'slave address
  I2cwbyte Adres                                         'asdress of EEPROM
  I2cwbyte Value                                         'value to write
  I2cstop                                                 'stop condition
  Waitms 10                                               'wait for 10 milliseconds
End Sub
'sample of reading a byte from EEPROM AT2404
  I2cstart                                                 'generate start
  I2cwbyte Addressw                                       'slave adsress
  I2cwbyte Adres                                           'address of EEPROM
  I2cstart                                                 'repeated start
  I2cwbyte Addressr                                       'slave address (read)
  I2crbyte Value , Nack                                   'read byte
  I2cstop                                                 'generate stop
End Sub
' when you want to control a chip with a larger memory like the 24c64 it requires an additional byte
' to be sent (consult the datasheet):
' Wires from the I2C address that are not connected will default to 0 in most cases!
'   I2cstart                                                'start condition
'   I2cwbyte &B1010_0000                                    'slave address
'   I2cwbyte H                                              'high address
'   I2cwbyte L                                              'low address
'   I2cwbyte Value                                          'value to write
'   I2cstop                                                 'stop condition
'   Waitms 10
