This option will set the randomize configuration.
CONFIG RND = 16|32
By default rnd() is created using 16 bit multiplying and division. This limits the maximum number to a word. The ___Rseed variable is a word.
When you need to have a bigger random number you can use the CONFIG RND = 32 option.
When using 32 bit resolution, only division is used to limit the number with the specified number.
Using 32 bit the ___Rseed will be a DWORD and not a WORD.
' Plot
' FT800 platform.
' Original code from http://gameduino2.proboards.com/thread/11/screen-plotting
' Comments by James Bowman:
' Sets up the whole screen as a framebuffer, in PALETTED mode, which should be good for the fractals.
' setpal() sets palette entry 'i' to a 32-bit ARGB color, and plot(x, y, i) sets a single pixel to index 'i'.
' Requires Bascom 2.0.7.8 or greater
$Regfile = "M328pdef.dat"
$Crystal = 8000000
$Baud = 19200
$HwStack = 80
$SwStack = 80
$FrameSize = 300
$NOTYPECHECK
Config ft800=spi , ftsave=0, ftdebug=0 , ftcs=portb.2, ftpd=portb.1
Config Base = 0
Config Submode = New
Config Spi = Hard, Interrupt = Off, Data_Order = Msb, Master = Yes, Polarity = Low, Phase = 0, Clockrate = 4, Noss = 1
SPSR = 1  ' Makes SPI run at 8Mhz instead of 4Mhz
Config RND = 32
$Include "FT800.inc"
$Include "FT800_Functions.inc"
Declare Sub setup
Declare Sub setpal (Byval i As Byte, Byval argb As Long)
Declare Sub plot (Byval x As Integer, Byval y As Integer, Byval i As Long)
dim dw as Dword
dim d1 as Dword
dim d2 as Dword
Spiinit
If FT800_Init() = 1 Then
   print "END"
   END    ' Initialise the FT800
end if
Setup
   d1 = rnd(Ft_DispWidth-1)
   d2 = rnd(Ft_DispHeight-1)
   plot d1, d2, rnd(255)
END
Sub Setup
   Local i As Byte
   CmdMemset 0, 0, Ft_DispWidth * Ft_DispHeight
   ClearScreen
   BitmapLayout PALETTED, Ft_DispWidth , Ft_DispHeight
   BitmapSize NEAREST, BORDER, BORDER, Ft_DispWidth, Ft_DispHeight
   BitmapSource 0
   Begin_G BITMAPS
   Vertex2ii 0, 0, 0, 0
   UpdateScreen
   setpal 0, &H00000000
   For i = 1 to 255
      setpal i, rnd(16777216) or &Hff000000
End Sub ' Setup
Sub SetPal (Byval i As Byte, Byval argb As Long)
   Local Temp1 As Long
   Temp1 =  i * 4
   Temp1 = Temp1 + Ram_Pal
   Wr32  Temp1 , argb
End Sub ' SetPal
Sub Plot(Byval x As Integer, Byval y As Integer, Byval i As Long)
   Local Temp1 As Long
   If x < Ft_DispWidth AND y < Ft_DispHeight Then
      Temp1 = Ft_DispWidth * y
      Temp1 = Temp1 + x
      Wr8 Temp1, i
End Sub ' Plot
