Executes a series of statements in a loop, as long as a given condition is true.
WHILE condition
statements
WEND
If the condition is true then any intervening statements are executed until the WEND statement is encountered.
BASCOM then returns to the WHILE statement and checks the condition.
If it is still true, the process is repeated.
If it is not true, execution resumes with the statement following the WEND statement.
So in contrast with the DO-LOOP structure, a WHILE-WEND condition is tested first so that if the condition fails, the statements in the WHILE-WEND structure are never executed.
'name : while_w.bas
'copyright : (c) 1995-2025, MCS Electronics
'purpose : demo: WHILE, WEND
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
Dim A As Byte
A = 1 'assign var
While A < 10 'test expression
Print A 'print var
Incr A 'increase by one
Wend 'continue loop
