Repeat a block of statements until condition is true.
DO
statements
LOOP [ UNTIL expression]
You can exit a DO..LOOP with the EXIT DO statement.
The DO-LOOP is always performed at least once.
The main part of your code can best be executed within a DO.. LOOP.
You could use a GOTO also but it is not as clear as the DO LOOP.
Main:
' code
GOTO Main
' Code
Of course in the example above, it is simple to see what happens, but when the code consist of a lot of lines of code, it is not so clear anymore what the GOTO Main does.
EXIT , WHILE-WEND , FOR-NEXT
'name : do_loop.bas
'copyright : (c) 1995-2021, MCS Electronics
'purpose : demo: DO, LOOP
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
Dim A As Byte
A = 1 'assign a var
Do 'begin a do..loop
Print A 'print var
Incr A 'increase by one
Loop Until A = 10 'do until a=10
'You can write a never-ending loop with the following code
'Your code goes here
