SELECT-CASE-END SELECT
Top  Previous  Next
Executes one of several statement blocks depending on the value of an expression.
SELECT CASE var
  CASE test1 : statements
[CASE test2 : statements ]
CASE ELSE : statements
END SELECT
Variable to test the value of
Test1
Value to test for.
Test2
Value to test for.
You can test for conditions to like:
CASE IS > 2 :
Another option is to test for a range :
CASE 2 TO 5 :
IF THEN
'name                     : case.bas
'copyright                : (c) 1995-2020, MCS Electronics
'purpose                  : demonstrates SELECT CASE statement
$regfile = "m48def.dat"                                   ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
Dim I As Byte                                             'dim variable
Dim S As String * 5 , Z As String * 5
Input "Enter value (0-255) " , I
Select Case I
  Case 1 : Print "1"
  Case 2 : Print "2"
  Case 3 To 5 : Print "3-5"
  Case Is >= 10 : Print ">= 10"
  Case Else : Print "Not in Case statement"
End Select
'note that a Boolean expression like > 3 must be preceded
'by the IS keyword
