IF-THEN-ELSE-END IF
IF-THEN-ELSE-END IF
Top  Previous  Next
Allows conditional execution or branching, based on the evaluation of a Boolean expression.
IF expression THEN
[ ELSEIF expression THEN ]
[ ELSE ]
END IF
Expression
Any expression that evaluates to true or false.
The one line version of IF can be used :
The use of [ELSE] is optional.
Tests like IF THEN can also be used with bits and bit indexes.
IF var.bit = 1 THEN
          ^--- bit is a variable or numeric constant in the range from 0-255
You can use OR or AND to test on multiple conditions. The conditions are evaluated from left to right.
IF A=OR A=OR A=OR B>10 THEN
IF A=AND A>THEN
Dim Var As Byte, Idx As Byte
Var = 255
Idx = 1
If Var.idx = 1 Then
   Print "Bit 1 is 1"
EndIf
ELSE
Dim A As Integer
A = 10
If A = 10 Then                                             'test expression
Print "This part is executed."                           'this will be printed
Else
Print "This will never be executed."                     'this not
If A = 10 Then Print "New in BASCOM"
If A = 10 Then Goto Label1 Else print "A<>10"
Label1:
Rem The following example shows enhanced use of IF THEN
If A.15 = 1 Then                                           'test for bit
Print "BIT 15 IS SET"
EndIf
Rem the following example shows the 1 line use of IF THEN [ELSE]
If A.15 = 0 Then Print "BIT 15 is cleared" Else Print "BIT 15 is set"
