Options Printer
Options Printer
Top  Previous  Next
With this option you can modify the printer settings.
options_printer
OPTION
DESCRIPTION
Font
Printer font to use when printing
Setup
Click to change the printer setup
Color
Will print in color. Use this only for color printers.
Wrap lines
Wrap long lines. When not enabled, long lines will be partial shown.
Print header
Print a header with the filename.
Line numbers
Will be the line number before each line.
Enable this to use the same syntax highlighting as the editor
Left margin
The left margin of the paper.
Right margin
The right margin of the paper.
Top margin
The top margin of the paper.
Bottom margin
The bottom margin of the paper.
