Options, Communication
Top  Previous  Next
options_communication
Communication
You can create maximal 8 terminal emulator windows. Each terminal window can have it's own settings.
The following description is for all terminal windows.
Item
Description
Port
The communication port.
Baud rate
The baud rate to use.
Parity
Parity, default None.
Data bits
Number of data bits, default 8.
Stop bits
Number of stop bits, default 1.
Handshake
The handshake used, default is none.
Emulation
Emulation to use, default none.
Font
Font type used by the emulator.
Background
Background color of the terminal emulator. It is a good idea to give every window a different background color for easy identification.
Auto Assign
When selected, the terminal will use the first free COM port.
Auto Open
When selected, the terminal will automatic open the COM port.
Log File
When selected, a log file is created.
Existing Ports only
This option will check the COM ports on your system that are usable. If your PC has only 1 COM port, the PORT setting will only show COM1.
If you do not select this option, the PORT setting will show COM port numbers from 1-255.
Prev
Select next terminal settings.
Select previous terminal settings.
