Mixing ASM and BASIC
Top  Previous  Next
BASCOM allows you to mix BASIC with assembly.
This can be very useful in some situations when you need full control of the generated code.
In order to use ASM you must start the line with the character !
Optional you can create a block of ASM using $ASM end $END ASM
Use CTRL + SPACE to get a list of ASM mnemonics.
For example :
Dim a As Byte At &H60        ' A is stored at location &H60
!Ldi R27 , $00          ' Load R27 with MSB of address
!Ldi R26 , $60          ' Load R26 with LSB of address
!Ld R1, X                  ' load memory location $60 into R1
!SWAP R1                  ' swap nibbles
As you can see the SWAP mnemonic is preceded by a ! sign. Without it, it would be the BASIC SWAP statement.
Another option is to use the assembler block directives:
$ASM
$END ASM
A special assembler helper function is provided to load the address into the register X or Z. Y can may not be used because it is used as the soft stack pointer.
Dim A As Byte                ' reserve space
LOADADR a, X                ' load address of variable named A into register pair X
This has the same effect as :
Ldi R26, $60                ' for example !
Ldi R27, $00                ' for example !
Some registers are used by BASCOM
R4 and R5 are used to point to the stack frame or the temp data storage
R6 is used to store some bit variables:
R6 bit 0 = flag for integer/word conversion
R6 bit 1 = temp bit space used for swapping bits
R6 bit 2 = error bit (ERR variable)
R6 bit 3 = show/noshow flag when using INPUT statement
R8 and R9 are used as a data pointer for the READ statement.
All other registers are used depending on the used statements.
To Load the address of a variable you must enclose them in brackets.
Dim B As Bit
To refer to the bit number you must precede the variable name by BIT.
Sbrs R16 , BIT.B  'notice the point!
Since this was the first dimensioned bit the bit number is 7. Bits are stored in bytes and the first dimensioned bit goes in the MS (most significant) bit.
To load an address of a label you must use :
LDI ZL, Low(lbl  * 1)
LDI ZH, High(lbl * 1)
Where ZL = R30 and may be R24, R26, R28 or R30
And ZH = R31 and may be R25, R27, R29 or R31.
These are so called register pairs that form a pointer.
When you want to use the LPM instruction to retrieve data you must multiply the address with 2 since the AVR object code consist of words.
LDI ZL, Low(lbl * 2)
LDI ZH, High(lbl * 2)
LPM ; get data into R0
Lbl:
Atmel mnemonics must be used to program in assembly.
You can download the pdf from www.atmel.com that shows how the different mnemonics are used.
Some points of attention :
* All instructions that use a constant as a parameter only work on the upper 16 registers (r16-r31)
So LDI R15,12 WILL NOT WORK
* The instruction SBR register, K
will work with K from 0-255. So you can set multiple bits!
The instruction SBI port, K will work with K from 0-7 and will set only ONE bit in a IO-port register.
The same applies to the CBR and CBI instructions.
You can use constants too:
.equ myval = (10+2)/4
ldi r24,myval+2 '5
ldi r24,asc("A")+1 ; load with 66
Or in BASIC with CONST :
CONST Myval = (10+2) / 4
Ldi r24,myval
ldd r26 , y + 0
ldd r27 , y + 1
The second parameter will also be put on the soft stack so :
The reference for the x variable will be changed :
ldd r26 , y + 2
ldd r27 , y + 3
ldd r26 , y + 0
ldd r27 , y + 1
[test]
test:
ldd r26,y+2                ; load address of x
ldd r27,y+3
ld r24,x                        ; get value into r24
inc r24                        ; value + 1
st x,r24                        ; put back
ldd r26,y+0                ; address of y
ldd r27,y+1
st x,r24                        ; store
ret                                ; ready
[end]
For example:
y + 0 and y + 1
To reference to test you must use :
ldd r26 , y + 4
ldd r27 , y + 5
To reference variable x
ldd r26 , y + 2
ldd r27 , y + 3
And to reference variable y
ldd r26 , y + 0
ldd r27 , y + 1
sub_test:
LOCALS
ldd r26, y+0
ldd r27 , y + 1
' define the used library
$lib "mylib.lib"
$external Test
'reserve some space
Dim Z As Byte
'call our own sub routine
Call Test(1 , Z)
.equ EEDR=$1d
In R24, EEDR
Translation
For example :
LDS r23, PORTG        ; get value of PORTG register
SBR r23,128        ; set bit 7
STS PORTG, R23
Special instructions
ADR Label        ; will create a word with the address of the label name
ADR2 Label        ; will create a word with the address of the label name, multiplied by 2 to get the byte address
               ; since word addresses are used. This is convenient when loading the Z-pointer to use (E)LPM.
.align        ; This directive will align the code to a 256 byte page so that the address LSB becomes 0.
               ; When storing data at an address where the LSB is zero, you can test for an overflow of the MSB only.
