BASCOM supports the mnemonics as defined by Atmel.
The Assembler accepts mnemonic instructions from the instruction set.
A summary of the instruction set mnemonics and their parameters is given here. For a detailed description of the Instruction set, refer to the AVR Data Book.
Mnemonics |
Operands |
Description |
Operation |
Flags |
Clock |
ARITHMETIC AND LOGIC INSTRUCTIONS |
ADD |
Rd, Rr |
Add without Carry |
Rd = Rd + Rr |
Z,C,N,V,H |
1 |
ADC |
Rd, Rr |
Add with Carry |
Rd = Rd + Rr + C |
Z,C,N,V,H |
1 |
SUB |
Rd, Rr |
Subtract without Carry |
Rd = Rd – Rr |
Z,C,N,V,H |
1 |
SUBI |
Rd, K |
Subtract Immediate |
Rd = Rd – K |
Z,C,N,V,H |
1 |
SBC |
Rd, Rr |
Subtract with Carry |
Rd = Rd - Rr - C |
Z,C,N,V,H |
1 |
SBCI |
Rd, K |
Subtract Immediate with Carry |
Rd = Rd - K - C |
Z,C,N,V,H |
1 |
AND |
Rd, Rr |
Logical AND |
Rd = Rd · Rr |
Z,N,V |
1 |
ANDI |
Rd, K |
Logical AND with Immediate |
Rd = Rd · K |
Z,N,V |
1 |
OR |
Rd, Rr |
Logical OR |
Rd = Rd v Rr |
Z,N,V |
1 |
ORI |
Rd, K |
Logical OR with Immediate |
Rd = Rd v K |
Z,N,V |
1 |
EOR |
Rd, Rr |
Exclusive OR |
Rd = Rd Å Rr |
Z,N,V |
1 |
COM |
Rd |
Ones Complement |
Rd = $FF - Rd |
Z,C,N,V |
1 |
NEG |
Rd |
Twos Complement |
Rd = $00 - Rd |
Z,C,N,V,H |
1 |
SBR |
Rd,K |
Set Bit(s) in Register |
Rd = Rd v K |
Z,N,V |
1 |
CBR |
Rd,K |
Clear Bit(s) in Register |
Rd = Rd · ($FFh - K) |
Z,N,V |
1 |
INC |
Rd |
Increment |
Rd = Rd + 1 |
Z,N,V |
1 |
DEC |
Rd |
Decrement |
Rd = Rd - 1 |
Z,N,V |
1 |
TST |
Rd |
Test for Zero or Minus |
Rd = Rd · Rd |
Z,N,V |
1 |
CLR |
Rd |
Clear Register |
Rd = Rd Å Rd |
Z,N,V |
1 |
SER |
Rd |
Set Register |
Rd = $FF |
None |
1 |
ADIW
Adiw r24, K6 |
Rdl, K6 |
Add Immediate to Word |
Rdh:Rdl = Rdh:Rdl + K |
Z,C,N,V,S |
2 |
SBIW
Sbiw R24,K6 |
Rdl, K6 |
Subtract Immediate from Word |
Rdh:Rdl = Rdh:Rdl - K |
Z,C,N,V,S |
2 |
MUL |
Rd,Rr |
Multiply Unsigned |
R1, R0 = Rd * Rr |
C |
2 * |
BRANCH INSTRUCTIONS |
RJMP |
K |
Relative Jump |
PC = PC + k + 1 |
None |
2 |
IJMP |
Indirect Jump to (Z) |
PC = Z |
None |
2 |
JMP |
K |
Jump |
PC = k |
None |
3 |
RCALL |
K |
Relative Call Subroutine |
PC = PC + k + 1 |
None |
3 |
ICALL |
Indirect Call to (Z) |
PC = Z |
None |
3 |
CALL |
K |
Call Subroutine |
PC = k |
None |
4 |
RET |
Subroutine Return |
PC = STACK |
None |
4 |
RETI |
Interrupt Return |
PC = STACK |
I |
4 |
CPSE |
Rd,Rr |
Compare, Skip if Equal |
if (Rd = Rr) PC = PC + 2 or 3 |
None |
1 / 2 |
CP |
Rd,Rr |
Compare |
Rd - Rr |
Z,C,N,V,H, |
1 |
CPC |
Rd,Rr |
Compare with Carry |
Rd - Rr - C |
Z,C,N,V,H |
1 |
CPI |
Rd,K |
Compare with Immediate |
Rd - K |
Z,C,N,V,H |
1 |
SBRC |
Rr, b |
Skip if Bit in Register Cleared |
If (Rr(b)=0) PC = PC + 2 or 3 |
None |
1 / 2 |
SBRS |
Rr, b |
Skip if Bit in Register Set |
If (Rr(b)=1) PC = PC + 2 or 3 |
None |
1 / 2 |
SBIC |
P, b |
Skip if Bit in I/O Register Cleared |
If(I/O(P,b)=0) PC = PC + 2 or 3 |
None |
2 / 3 |
SBIS |
P, b |
Skip if Bit in I/O Register Set |
If(I/O(P,b)=1) PC = PC + 2 or 3 |
None |
2 / 3 |
BRBS |
s, k |
Branch if Status Flag Set |
if (SREG(s) = 1) then PC=PC+k + 1 |
None |
1 / 2 |
BRBC |
s, k |
Branch if Status Flag Cleared |
if (SREG(s) = 0) then PC=PC+k + 1 |
None |
1 / 2 |
BREQ |
K |
Branch if Equal |
if (Z = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRNE |
K |
Branch if Not Equal |
if (Z = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRCS |
K |
Branch if Carry Set |
if (C = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRCC |
K |
Branch if Carry Cleared |
if (C = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRSH |
K |
Branch if Same or Higher |
None |
1 / 2 |
BRLO |
K |
Branch if Lower |
None |
1 / 2 |
BRMI |
K |
Branch if Minus |
if (N = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRPL |
K |
Branch if Plus |
if (N = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRGE |
K |
Branch if Greater or Equal, Signed |
if (N V= 0) then PC = PC+ k + 1 |
None |
1 / 2 |
BRLT |
K |
Branch if Less Than, Signed |
if (N V= 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRHS |
K |
Branch if Half Carry Flag Set |
if (H = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRHC |
K |
Branch if Half Carry Flag Cleared |
if (H = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRTS |
K |
Branch if T Flag Set |
if (T = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRTC |
K |
Branch if T Flag Cleared |
if (T = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRVS |
K |
Branch if Overflow Flag is Set |
if (V = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRVC |
K |
Branch if Overflow Flag is Cleared |
if (V = 0) then PC = PC + k + 1 |
None |
1 / 2 |
BRIE |
K |
Branch if Interrupt Enabled |
if ( I = 1) then PC = PC + k + 1 |
None |
1 / 2 |
BRID |
K |
Branch if Interrupt Disabled |
if ( I = 0) then PC = PC + k + 1 |
None |
1 / 2 |
DATA TRANSFER INSTRUCTIONS |
MOV |
Rd, Rr |
Copy Register |
Rd = Rr |
None |
1 |
LDI |
Rd, K |
Load Immediate |
Rd = K |
None |
1 |
LDS |
Rd, k |
Load Direct |
Rd = (k) |
None |
2 |
LD |
Rd, X |
Load Indirect |
Rd = (X) |
None |
2 |
LD |
Rd, X+ |
Load Indirect and Post-Increment |
Rd = (X), X = X + 1 |
None |
2 |
LD |
Rd, -X |
Load Indirect and Pre-Decrement |
X = X - 1, Rd =(X) |
None |
2 |
LD |
Rd, Y |
Load Indirect |
Rd = (Y) |
None |
2 |
LD |
Rd, Y+ |
Rd = (Y), Y = Y + 1 |
None |
2 |
LD |
Rd, -Y |
Y = Y - 1, Rd = (Y) |
None |
2 |
LDD |
Rd,Y+q |
Load Indirect with Displacement |
Rd = (Y + q) |
None |
2 |
LD |
Rd, Z |
Load Indirect |
Rd = (Z) |
None |
2 |
LD |
Rd, Z+ |
Rd = (Z), Z = Z+1 |
None |
2 |
LD |
Rd, -Z |
Z = Z - 1, Rd = (Z) |
None |
2 |
LDD |
Rd, Z+q |
Rd = (Z + q) |
None |
2 |
STS |
k, Rr |
Store Direct |
(k) = Rr |
None |
2 |
ST |
X, Rr |
Store Indirect |
(X) = Rr |
None |
2 |
ST |
X+, Rr |
Store Indirect and Post-Increment |
(X) = Rr, X = X + 1 |
None |
2 |
ST |
-X, Rr |
Store Indirect and Pre-Decrement |
X = X - 1, (X) = Rr |
None |
2 |
ST |
Y, Rr |
Store Indirect |
(Y) = Rr |
None |
2 |
ST |
Y+, Rr |
(Y) = Rr, Y = Y + 1 |
None |
2 |
ST |
-Y, Rr |
Y = Y - 1, (Y) = Rr |
None |
2 |
STD |
Y+q,Rr |
Store Indirect with Displacement |
(Y + q) = Rr |
None |
2 |
ST |
Z, Rr |
Store Indirect |
(Z) = Rr |
None |
2 |
ST |
Z+, Rr |
(Z) = Rr, Z = Z + 1 |
None |
2 |
ST |
-Z, Rr |
Z = Z - 1, (Z) = Rr |
None |
2 |
STD |
Z+q,Rr |
(Z + q) = Rr |
None |
2 |
LPM |
Load Program Memory |
R0 =(Z) |
None |
3 |
IN |
Rd, P |
In Port |
Rd = P |
None |
1 |
OUT |
P, Rr |
Out Port |
P = Rr |
None |
1 |
PUSH |
Rr |
Push Register on Stack |
STACK = Rr |
None |
2 |
POP |
Rd |
Pop Register from Stack |
Rd = STACK |
None |
2 |
BIT AND BIT-TEST INSTRUCTIONS |
LSL |
Rd |
Logical Shift Left |
Rd(n+1) =Rd(n),Rd(0)= 0,C=Rd(7) |
Z,C,N,V,H |
1 |
LSR |
Rd |
Logical Shift Right |
Rd(n) = Rd(n+1), Rd(7) =0, C=Rd(0) |
Z,C,N,V |
1 |
ROL |
Rd |
Rotate Left Through Carry |
Rd(0) =C, Rd(n+1) =Rd(n),C=Rd(7) |
Z,C,N,V,H |
1 |
ROR |
Rd |
Rotate Right Through Carry |
Rd(7) =C,Rd(n) =Rd(n+1),C¬Rd(0) |
Z,C,N,V |
1 |
ASR |
Rd |
Arithmetic Shift Right |
Rd(n) = Rd(n+1), n=0..6 |
Z,C,N,V |
1 |
SWAP |
Rd |
Swap Nibbles |
Rd(3..0) « Rd(7..4) |
None |
1 |
BSET |
S |
Flag Set |
SREG(s) = 1 |
SREG(s) |
1 |
BCLR |
S |
Flag Clear |
SREG(s) = 0 |
SREG(s) |
1 |
SBI |
P, b |
Set Bit in I/O Register |
I/O(P, b) = 1 |
None |
2 |
CBI |
P, b |
Clear Bit in I/O Register |
I/O(P, b) = 0 |
None |
2 |
BST |
Rr, b |
Bit Store from Register to T |
T = Rr(b) |
T |
1 |
BLD |
Rd, b |
Bit load from T to Register |
Rd(b) = T |
None |
1 |
SEC |
Set Carry |
C = 1 |
C |
1 |
CLC |
Clear Carry |
C = 0 |
C |
1 |
SEN |
Set Negative Flag |
N = 1 |
N |
1 |
CLN |
Clear Negative Flag |
N = 0 |
N |
1 |
SEZ |
Set Zero Flag |
Z = 1 |
Z |
1 |
CLZ |
Clear Zero Flag |
Z = 0 |
Z |
1 |
SEI |
Global Interrupt Enable |
I = 1 |
I |
1 |
CLI |
Global Interrupt Disable |
I = 0 |
I |
1 |
SES |
Set Signed Test Flag |
S = 1 |
S |
1 |
CLS |
Clear Signed Test Flag |
S = 0 |
S |
1 |
SEV |
Set Twos Complement Overflow |
V = 1 |
V |
1 |
CLV |
Clear Twos Complement Overflow |
V = 0 |
V |
1 |
SET |
Set T in SREG |
T = 1 |
T |
1 |
CLT |
Clear T in SREG |
T = 0 |
T |
1 |
SHE |
Set Half Carry Flag in SREG |
H = 1 |
H |
1 |
CLH |
Clear Half Carry Flag in SREG |
H = 0 |
H |
1 |
NOP |
No Operation |
None |
1 |
SLEEP |
Sleep |
None |
1 |
WDR |
Watchdog Reset |
None |
1 |
* ) Not available in base-line microcontrollers
The Assembler is not case sensitive.
The operands have the following forms:
Rd: R0-R31 or R16-R31 (depending on instruction)
Rr: R0-R31
b: Constant (0-7)
s: Constant (0-7)
P: Constant (0-31/63)
K: Constant (0-255)
k: Constant, value range depending on instruction.
q: Constant (0-63)
Rdl: R24, R26, R28, R30. For ADIW and SBIW instructions
