File Open
Top  Previous  Next
With this option you can load an existing file from disk.
BASCOM saves files in standard ASCII format. Therefore, if you want to load a file that was made with another editor be sure that it is saved as an ASCII file. Most programs allow you to export the file as a DOS or ASCII file.
The following dialog window will be shown.
file-open
You can preview the supported files at the right of the dialog window.
noticeWhile you can open and edit files, they are not added to the project ! Use the PM to add existing files to your project.
File open shortcut : fileopen, CTRL+O
