This configuration statement will configure the XTINY voltage reference.
CONFIG VREF=Dummy, ADCx=ref1,DACx|AC0=ref2, force_adcX=opt1,force_dacX|force_acX=opt2
dummy  |
There is no actual global setting for VREF so the only option is dummy  |
ADCx
This will set the voltage reference for the ADC0/ADC1 to the specified value of ref1. The X represents the number 0 or 1 which represents ADC0 and ADC1.
 The voltage reference for the ADC ref1 can be : - 0.55V - 1.1V - 4.3V - 1.5V
 The default is 0.55V
 The voltage reference can not exceed the supply voltage. So 4.3 is only possible when VCC is 5V  |
force_adcX  |
This option allows to force the reference to be running even if it is not requested. A value of ENABLED will force the reference to be on. A value of DISABLED which is the default will set the reference in automatic mode. In this mode the reference is turned on when requested. This will save power.  |
DACx AC0  |
This will set the voltage reference for the DACx and/or ACx to the specified value of ref2. Note that ADCx and DACx/ACx reference can be set in depended of each other. The X indicates a number 0,1 or 2 which represents DAC0, DAC1 and DAC2.
 The voltage reference for the DAC which can be : - 0.55V - 1.1V - 4.3V - 1.5V
force_dacX force_acX  |
 As for the other options, the X represents the peripheral DAC/AC.  |
Note that not all processors have an ADC and/or DAC. It depends on the processor.
Some processors have multiple ADC and/or DAC.
The DAC and AC are grouped together. The IDE will show the proper options depending on the chosen processor when using CTRL+SPACE
