CONFIG ADC0-ADCX
Top  Previous  Next
Configures the A/D converter of the Xtiny
CONFIG ADC0 | ADCx = mode, RUNMODE=runmode, RESOLUTION=res, ADC=adc, SAMPLE_ACCU=samp_acc, SAMPLE_CAP=samp_cap, SAMPLE_DELAY=samp_dly, SAMPLE_LEN=samp_len,
REFERENCE=ref,PRESCALER=pre, INIT_DELAY=init_dly,ASDV=asdv,WINDOW_COMP=win_cmp, MUX=mux
mode
AD converter mode.
- SINGLE (default mode for a single conversion)
- FREE. In FREE mode a new conversion cycle is started immediately after a previous conversion has completed.
runmode
Possible values:
ENABLED : In Standby sleep mode, the peripheral continues operation
DISABLED : In Standby sleep mode, the peripheral is halted
res
The resolution of the conversion. Valid values are :
- 8BIT
- 10BIT. This is the default
adc
ENABLED or DISABLED.
By default the AD converter is DISABLED.
samp_acc
This value selects how many consecutive ADC sampling results are accumulated automatically.  Possible values :
- 0 :  (accumulation disabled, default value)
- 2, 4,8,16,32,64 : number of accumulated samples.
samp_cap
Sample capacitance selection.
Possible values :
- BELOW_1V : Recommended for reference voltage values below 1V.
- ABOVE_1V : Reduced size of sampling capacitance. Recommended for higher reference voltages.
samp_dly
Sampling Delay Selection : Numeric constant between 0 and 15.
These bits define the delay between consecutive ADC samples. The programmable Sampling Delay allows modifying
the sampling frequency during hardware accumulation, to suppress periodic noise sources that may otherwise disturb the sampling. The SAMPDLY field can be also modified automatically from sampling cycle to another, by setting the ASDV bit. The delay is expressed as CLK_ADC cycles and is given directly by the bitfield setting. The sampling cap is kept open during the delay.
samp_len
Sample Length. Numeric constant between 0 and 31.
These bits extend the ADC sampling length in number of CLK_ADC cycles. By default the sampling time is two CLK_ADC cycles. Increasing the sampling length allows sampling sources with higher impedance. The total conversion time increased with the selected sampling length.
ref
Voltage Reference selection. Possible values :
- INTERNAL : internal reference. See CONFIG VREF
- VDD : VDD
prescale
Prescaler selection. This is the division from the peripheral clock to the ADC clock. Possible values :
2,4,8,16,32,64,128,256
init_dly
Initialization delay. These bits defines the initialization/startup delay before the first sample when enabling the ADC or changing to
internal reference voltage. Setting this delay will ensure that the reference, muxes, etc are ready before starting the first conversion. The initialization delay will also take place when waking up from deep sleep to do a measurement.
The delay is expressed as a number of CLK_ADC cycles.
Possible values :
- 0   : Delay 0 CLK_CYCLES (no delay)
- 16 : Delay 16 CLK_CYCLES
- 32 : Delay 32 CLK_CYCLES
- 64 : Delay 64 CLK_CYCLES
- 128 : Delay 128 CLK_CYCLES
- 256 : Delay 256 CLK_CYCLES
asdv
Automatic Sampling Delay Variation. ENABLED or DISABLED.
Selecting ENABLED, enables automatic sampling delay variation between ADC conversions. The purpose of varying sampling instant is to randomize the sampling instant and thus avoid standing frequency components in frequency
spectrum. The value of the SAMPDLY bits is automatically incremented by one after each sample.
When the Automatic Sampling Delay Variation is enabled and the SAMPDLY value reaches &HF, it wraps around to 0.
win_cmp
Window Comparator Mode.
This field enables and defines when the interrupt flag is set in Window Comparator mode. RESULT is the 16-bit accumulator result. WINLT and WINHT are 16-bit lower threshold value and 16-bit higher threshold value,
respectively. Possible values :
- NONE : No windows comparison (default)
- BELOW : result < WINLT
- ABOVE : result > WINHT
- INSIDE : WINLT < result  < WINHT
- OUTSIDE : result < WINLT or result > WINHT
mux
Mux position. This bit field selects which single-ended analog input is connected to the ADC. If these bits are changed during a conversion, the change will not take effect until this conversion is complete.
Possible values :
- GND : 0V, GND
- TEMPSENSE : Temperature sensor
- INTREF : Internal reference (from VREF)
- DAC0 : DAC0 output
0-11  : ADC input pin 0-11
