CONFIG PORT
Top  Previous  Next
Sets the port or a port pin to the right data direction.
CONFIG PORTx = state
CONFIG PINx.y = state
state
A numeric constant that can be INPUT or OUTPUT.
INPUT will set the data direction register to input for port X.
OUTPUT will set the data direction to output for port X.
You can also use a number for state. &B00001111, will set the upper nibble to input and the lower nibble to output.
You can also set a single port pin with the CONFIG PIN = state, statement.
Again, you can use INPUT, OUTPUT or a number. In this case the number can be only zero or one.
The best way to set the data direction for more than 1 pin, is to use the CONFIG PORT, statement and not multiple lines with CONFIG PIN statements.
See Also
AVR Internal hardware ports
'name                     : port.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demo: PortB and PortD
$regfile = "m48def.dat"                                   ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
Dim A As Byte , Count As Byte
'configure PORT D for input mode
Config Portd = Input
'reading the PORT, will read the latch, that is the value
'you have written to the PORT.
'This is not the same as reading the logical values on the pins!
'When you want to know the logical state of the attached hardware,
'you MUST use the PIN register.
A = Pind
'a port or SFR can be treated as a byte
A = A And Portd
Print A                                                     'print it
Bitwait Pind.7 , Reset                                     'wait until bit is low
'We will use port B for output
Config Portb = Output
'assign value
Portb = 10                                                 'set port B to 10
Portb = Portb And 2
Set Portb.0                                                 'set bit 0 of port B to 1
Incr Portb
'Now a light show on the STK200
Count = 0
Incr Count
Portb = 1
For A = 1 To 8
  Rotate Portb , Left                                   'rotate bits left
  Wait 1
'the following 2 lines do the same as the previous loop
'but there is no delay
'  Portb = 1
'  Rotate Portb , Left , 8
Loop Until Count = 10
Print "Ready"
'Again, note that the AVR port pins have a data direction register
'when you want to use a pin as an input it must be set low first
'you can do this by writing zeros to the DDRx:
'DDRB =&B11110000  'this will set portb1.0,portb.1,portb.2 and portb.3 to use as inputs.
'So : when you want to use a pin as an input set it low first in the DDRx!
'     and read with PINx
'     and when you want to use the pin as output, write a 1 first
'     and write the value to PORTx
