Select and enables the oscillators available to the Xtiny/MegaX and AVRX
See also AVRX
CONFIG OSC=ENABLED|DISABLED , OPTIONn=VALUEn
The options and values depend on the processor. Below is a list of options and values.
OPTION |
VALUE |
OSC |
ENABLED. The internal HF oscillator is always enabled. There is no option to disable it. So this is a kind of dummy variable. |
RUNMODE |
DISABLED or ENABLED. With RUNMODE enabled the oscillator will be forced to be always on. Otherwise it is only on when required. |
AUTOTUNE |
DISABLED or ENABLED. When enabled the HF oscillator can be tuned with the 32 KHz crystal oscillator. There is a CLKCTRL_OSCHFTUNE register that can be modified to tune. |
FREQUENCY |
This selects the frequency of the HF oscillator. Options are : [1MHZ,2MHZ,3MHZ,4MHZ,8MHZ,12MHZ,16MHZ,20MHZ,24MHZ]. Notice that the $CRYSTAL directive should match the setting. |
PLL_RUNMODE |
PLL_SOURCE |
OSCHF or XOSCHF. THis is the clock source for the PLL. Which is either the internal HF OSC or the external HF OSC. |
PLL_MUL |
DISABLED, 2 or 3. This is the PLL multiplication factor. With DISABLED, the PLL is disabled. |
OSC32_RUNMODE |
XOSC32_RUNMODE |
DISBLED or ENABLED. With RUNMODE enabled the oscillator will be forced to be always on. Otherwise it is only on when required. |
XOSC32 |
DISBLED or ENABLED. This option allows to enable the EXTERNAL 32 KHZ oscillator. |
XOSC32_SEL_STARTUP |
XTAL_1KCLK , XTAL_16KCLK, XTAL_32KCLK or XTAL_64KCLK. These options set the 32 OSC crystal start up time in cycles. |
XOSC32_EXT_SRC |
EXT_XTAL or EXT_CLOCK_TOSC1. The source for the oscillaror. Either a crystal or an external clock signal on pin 1. |
XOSC32_LPMODE |
DISABLED or ENABLED. This option sets the Low Power mode. |
XOSCHF |
DISABLED,ENABLED] |
XOSCHF_RUNMODE |
XOSCHF_SEL_STARTUP |
XTAL_256CLK,XTAL_1KCLK or XTAL_4KCLK. The external HF oscillator crystal start up time. |
XOSCHF_EXT_SRC |
EXT_XTAL or EXT_CLOCK_XTALHF1. This options selects the source for the external HF oscillator clock source. Either a crystal or an external clock signal on the XTALHF1 pin |
XOSCHF_RANGE |
MAX_8MHZ,MAX_16MHZ,MAX_24MHZ or MAX_32MHZ. The maximum frequency supported for the external crystal. The larger the range selected the higher the current consumption by the oscillator. |
As you can see there are a number of oscillators available.
The internal HF oscillator. An internal 32 KHZ oscillator. An external 32 KHz xtal can be connected for an external 32 KHz oscillator, and a HF crystal can be connected to a High Frequency external crystal.
