The AVR-DOS file system is written by Josef Franz Vögel. He can be contacted via the BASCOM forum. Note that it is not permitted to use the AVR-DOS file system for commercial applications without the purchase of a license. A license comes with the ASM source.
You can buy a user license that is suited for most private users.
When you develop a commercial product with AVR-DOS you need the company license.
The ASM source is shipped with both licenses.
Josef has put a lot of effort in writing and especially testing the routines.
Josef nor MCS Electronics can be held responsible for any damage or data loss of your CF-cards.
The File-System works with Compact – Flash Cards (see AN 123 Accessing a Compact Flash Card from BASCOM and Compact Flash ) and is written for the needs for embedded systems for logging data. There are further functions for binary read and write.
You do not need AN123. AN123 was used to develop AVR-DOS. So you should use AVR-DOS.
The intention in developing the DOS – file system was to keep close to the equivalent VB functions.
The Filesystem works with:
| • | FAT16, this means you need to use >= 32MB CF cards |
| • | FAT32 |
| • | Short file name (8.3) |
| • | (Files with a long file name can be accessed by their short file name alias) |
| • | Files in Root Directory. The root dir can store 512 files. Take in mind that when you use long file names, less filenames can be stored. |
| • | Files in SUBDIRS |
Requirements:
| • | Hardware: see AN 123 on http://www.mcselec.com/an_123.htm |
| • | Software: appr. 2K-Word Code-Space (4000 Bytes) |
| • | SRAM: 561 Bytes for File system Info and DIR-Handle buffer |
| • | 517 Bytes if FAT is handled in own buffer (for higher speed), otherwise it is handled with the DIR Buffer |
| • | 534 Bytes for each File handle |
| • | This means that a Mega103 or Mega128 is the perfect chip. Other chips have too little internal memory. You could use XRAM memory too with a Mega8515 for example. |
File System Configuration in CONFIG_AVR-DOS.BAS
cFileHandles: |
Count of File handles: for each file opened at same time, a file handle buffer of 534 Bytes is needed |
cSepFATHandle: |
For higher speed in handling file operations the FAT info can be stored in a own buffer, which needs additional 517 Bytes.
Assign Constant cSepFATHandle with 1, if wanted, otherwise with 0. |
Memory Usage of DOS – File System:
1. General File System information
Variable Name |
Type |
Usage |
gbDOSError |
Byte |
holds DOS Error of last file handling routine |
gbFileSystem |
Byte |
File System Code from Master Boot Record |
glFATFirstSector |
Long |
Number of first Sector of FAT Area on the Card |
gbNumberOfFATs |
Byte |
Count of FAT copies |
gwSectorsPerFat |
Word |
Count of Sectors per FAT |
glRootFirstSector |
Long |
Number of first Sector of Root Area on the Card |
gwRootEntries |
Word |
Count of Root Entries |
glDataFirstSector |
Long |
Number of first Sector of Data Area on the Card |
gbSectorsPerCluster |
Byte |
Count of Sectors per Cluster |
gwMaxClusterNumber |
Word |
Highest usable Cluster number |
gwLastSearchedCluster |
Word |
Last cluster number found as free |
gwFreeDirEntry |
Word |
Last directory entry number found as free |
glFS_Temp1 |
Long |
temporary Long variable for file system |
gsTempFileName |
String * 11 |
temporary String for converting file names |
2. Directory
Variable Name |
Type |
Usage |
gwDirRootEntry |
Word |
number of last handled root entry |
glDirSectorNumber |
Long |
Number of current loaded Sector |
gbDirBufferStatus |
Byte |
Buffer Status |
gbDirBuffer |
Byte (512) |
Buffer for directory Sector |
3. FAT
Variable Name |
Type |
Usage |
glFATSectorNumber |
Long |
Number of current loaded FAT sector |
gbFATBufferStatus |
Byte |
Buffer status |
gbFATBuffer |
Byte(512) |
buffer for FAT sector |
4. File handling
Each file handle has a block of 534 Bytes in the variable abFileHandle which is a byte-array of size (534 * cFileHandles)
Variable Name |
Type |
Usage |
FileNumber |
Byte |
File number for identification of the file in I/O operations to the opened file |
FileMode |
Byte |
File open mode |
FileRootEntry |
Word |
Number of root entry |
FileFirstCluster |
Word |
First cluster |
FATCluster |
Word |
cluster of current loaded sector |
FileSize |
Long |
file size in bytes |
FilePosition |
Long |
file pointer (next read/write) 0-based |
FileSectorNumber |
Long |
number of current loaded sector |
FileBufferStatus |
Byte |
buffer Status |
FileBuffer |
Byte(512) |
buffer for the file sector |
SectorTerminator |
Byte |
additional 00 Byte (string terminator) for direct reading ASCII files from the buffer |
Error Codes:
Code |
Compiler – Alias |
Remark |
0 |
cpNoError |
No Error |
1 |
cpEndOfFile |
Attempt behind End of File |
17 |
cpNoMBR |
Sector 0 on Card is not a Master Boot Record |
18 |
cpNoPBR |
No Partition Sector |
19 |
cpFileSystemNotSupported |
Only FAT16 File system is supported |
20 |
cpSectorSizeNotSupported |
Only sector size of 512 Bytes is supported |
21 |
cpSectorsPerClusterNotSupported |
Only 1, 2, 4, 8, 16, 32, 64 Sectors per Cluster is supported. This are values of normal formatted partitions. Exotic sizes, which are not power of 2 are not supported |
33 |
cpNoNextCluster |
Error in file cluster chain |
34 |
cpNoFreeCluster |
No free cluster to allocate (Disk full) |
35 |
cpClusterError |
49 |
cpNoFreeDirEntry |
Directory full |
50 |
cpFileExist |
65 |
cpNoFreeFileNumber |
No free file number available, only theoretical error, if 255 file handles in use |
66 |
cpFileNotFound |
File not found |
67 |
cpFileNumberNotFound |
No file handle with such file number |
68 |
cpFileOpenNoHandle |
All file handles occupied |
69 |
cpFileOpenHandleInUse |
File handle number in use, can't create a new file handle with same file number |
70 |
cpFileOpenShareConflict |
Tried to open a file in read and write modus in two file handles |
71 |
cpFileInUse |
Can't delete file, which is in use |
72 |
cpFileReadOnly |
Can't open a read only file for writing |
73 |
cpFileNoWildCardAllowed |
No wildcard allowed in this function |
97 |
cpFilePositionError |
98 |
cpFileAccessError |
function not allowed in this file open mode |
99 |
cpInvalidFilePosition |
new file position pointer is invalid (minus or 0) |
100 |
cpFileSizeToGreat |
File size to great for function BLoad |
Buffer Status: Bit definitions of Buffer Status Byte (Directory, FAT and File)
Bit |
DIR |
FAT |
File |
Compiler Alias |
Remark |
0 (LSB) |
dBOF |
Bottom of File (not yet supported) |
1 |
dEOF |
End of File |
2 |
dEOFinSector |
End of File in this sector (last sector) |
3 |
dWritePending |
Something was written to sector, it must be saved to Card, before loading next sector |
4 |
dFATSector |
This is an FAT Sector, at writing to Card, Number of FAT copies must be checked and copy updated if necessary |
5 |
dFileEmpty |
File is empty, no sector (Cluster) is allocated in FAT to this file |
Validity of the file I/O operations regarding the opening modes
Open mode |
Action |
Input |
Output |
Append |
Binary |
Attr |
Close |
Put |
Get |
LOF |
LOC |
EOF |
1) |
1) |
SEEK |
SEEK-Set |
Line Input |
Input |
Write |
1) Position pointer is always at End of File
Supported statements and functions:
INITFILESYSTEM , OPEN , CLOSE, FLUSH , PRINT, LINE INPUT, LOC, LOF , EOF , FREEFILE , FILEATTR , SEEK , BSAVE , BLOAD , KILL , DISKFREE , DISKSIZE , GET , PUT ,FILEDATE , FILETIME , FILEDATETIME , DIR , WRITE , INPUT , FILELEN
