View Vertical Splitter
Top  Previous  Next
You can split the editor window into two parts. By default you use the horizontal splitter marked with the arrow.
view_split_1
This will create a split screen :
view_split_2
With the option Vertical Splitter, you switch between horizontal en vertical splitter.
The splitter is located near the code explorer window.
view_split_4
This will result in a vertical split window.
view_split_5
When you chose the vertical splitter option again the window will be split horizontal again.
Notice that in order to show two different code windows you need to open the two windows and use Tile Vertically.
