View Project Files
View Project Files
Top  Previous  Next
Shows the Project Explore Window.
ide_view_project_Explorer
The project explorer window is intended to be used in project mode. Project mode is a mode where all files belong to one project. Here you have a main file and optional include files.
The project explorer is a dock able window. It lists all files assigned to the project. When you double click a file, it will be opened in the editor.
- Use the ADD button to add files to the project
- Use the REMOVE button to remove files from the project. Files you remove are only removed from the project, they are not removed from disk
- Use SET MAIN to set the main project file. The main project file is the file that is compiled.
