Running BASCOM-AVR
Top  Previous  Next
After you have installed BASCOM, you will find a program entry under MCS Electronics\BASAVR
Double-click the BASAVR icon bascom-icon to run BASCOM.
The following window will appear. (If this is your first run, the edit window will be empty.)
bascomide
The most-recently opened project will be opened automatically. Like most Windows programs, there is a menu and  a toolbar. The toolbar can be customized. To do this, place the mouse cursor right beside the 'Help' menu.
Then right-click. You can turn on/off the toolbars or you can choose 'Customize'.
This will show the following window:
toolbar_cust
You have the option to create new Toolbars or the reset the toolbars to the default.
To place a new button on a menu bar, select the 'Commands' TAB.
toolbar_commands
In the example above, the Program Category has been selected and at the right pane, all buttons that belong to the Program-category are shown.
You can now select a button and drag & drop it to the Toolbar. To remove a button from the Toolbar, you drag it out of the Toolbar and release the left mouse button.
On the Options-TAB you can further customize the Toolbar:
setup_options
To preserve screen space there are no large icons available.
Option
Description
Menus show recent used commands first
With this option the IDE will learn the menu options you use. It will show only the most used menu options. The idea is that you can find your option quicker this way.
Show full menus after a short delay
This option will show the remaining menu options after short delay so you do not need to click another menu option to show all menu options.
Reset my usage data
This option will reset the data the IDE has collected about your menu choices.
Show Tool tips on toolbars
This option is on by default and it will show a tool tip when you hold the mouse cursor above a toolbar button
Show shortcut keys in Tool tips
This option is on by default and it will show the shortcut in the tool tip. For example CTRL+C for the Copy button.
See Also
The BASCOM-IDE
