Use this option to view information concerning the result of the compilation.
Under Options, Compiler Settings you can specify which files need to be generated. You need to select .RPT files in order to generate/view them.
The report file will be loaded in a new editor TAB. While you can edit the report, take care that it will be overwritten the next time you compile the project.
Information provided in the report:
Info |
Description |
Report |
Name of the program |
Date and time |
The compilation date and time. |
Compiler |
The version of the compiler. |
Processor |
The selected target processor. |
SRAM |
Size of microprocessor SRAM (internal RAM). |
EEPROM |
Size of microprocessor EEPROM (internal EEPROM). |
ROMSIZE |
Size of the microprocessor FLASH ROM. |
ROMIMAGE |
Size of the compiled program. |
BAUD |
Selected baud rate. |
XTAL |
Selected XTAL or frequency. |
BAUD error |
The error percentage of the baud rate. |
XRAM |
Size of external RAM if available. |
Stack start |
The location in memory, where the hardware stack points to. The HW-stack pointer grows downward. |
S-Stacksize |
The size of the software stack. |
S-Stackstart |
The location in memory where the software stack pointer points to. The software stack pointer grows downward. |
Framesize |
The size of the frame. The frame is used for storing local variables. |
Framestart |
The location in memory where the frame starts. |
LCD address |
The address that must be placed on the bus to enable the LCD display E-line. |
LCD RS |
The address that must be placed on the bus to enable the LCD RS-line |
LCD mode |
The mode the LCD display is used with. 4 bit mode or 8 bit mode. |
LCD DB7-DB4 |
The port pins used for controlling the LCD in pin mode. |
LCD E |
The port pin used to control the LCD enable line. |
LCD RS |
The port pin used to control the LCD RS line. |
Variable |
The variable name and address in memory |
Constant |
Constants name and value
Some internal constants are :
_CHIP : number that identifies the selected chip _RAMSIZE : size of SRAM _ERAMSIZE : size of EEPROM _XTAL : value of crystal _BUILD : number that identifies the version of the compiler _COMPILER : number that identifies the platform of the compiler
Warnings |
This is a list with variables that are dimensioned but not used. Some of them are registers which you can ignore. |
EEPROM binary image map |
This is a list of all ERAM variables with their value. It is only shown when DATA lines are used to create the EEP file. (EEPROM binary image). |
File show result shortcut :
,CTRL+W
