Environment, IDE
OPTION |
DESCRIPTION |
Language |
The language to use for the IDE. |
Show TABs |
Select this option to show each window in a TAB. The TAB makes it easy to select a window but occupies screen space. To get more screen space you can turn this option off. |
Save project before compile |
This option is intended to be used together with the stand alone compiler DLL. It need the file saved to disk. |
Quick Edit |
This option will disable some advanced features. It will result in quicker editing. |
Disable Error check |
This option will turn off error checking. |
ASM Syntax Check |
This option will turn on ASM syntax checking. |
Show dead code |
This option will show all dead code in grey. Dead code is code that is never executed. For example, a variable that is dimmed but never assigned. Or a function/sub that is created but never called. Or a variable that is assigned multiple times like : var = 10 var = 12 Obvious, the variable will be 12 so the first line is considered dead code. With $NOOPT you can turn off dead code checking. With $OPT you can enabled it again. Some registers need a double write. In such case a dead code elimination can not be used. |
Auto Add PDF |
When enabled this option will add the processor PDF file to the project tree, when you change the $regfile value |
Auto Download PDF |
When enabled this option will download a PDF when it is not found in the PDF folder. The download will occur when you change the $regfile value and the PDF is not found. The 'Auto Add PDF' option need to be enabled for this option. |
Asociate BPJ |
To associate the BPJ extension with the BASCOM-IDE you can click this button. After BPJ is associated, all BPJ (bascom project files) will have the same icon as the BASCOM-IDE. You can also launch bascom from the explorer then by double clicking a BPJ file. |
