Send constant or variable to LCD display.
LCD x
X |
Variable or constant to display. |
More variables can be displayed separated by the ; -sign
LCD a ; b1 ; "constant"
The LCD statement behaves just like the PRINT statement. So SPC() can be used too.
The only difference with PRINT is that no CR+LF is added when you send data to the LCD.
$LCD , $LCDRS , CONFIG LCD , SPC , CLS , INITLCD , SHIFTLCD , SHIFTCURSOR , CURSOR , LCDCMD, LCDDATA
'name : lcd.bas
'copyright : (c) 1995-2021, MCS Electronics
'purpose : demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
' CURSOR, DISPLAY
'micro : Mega8515
'suited for demo : yes
'commercial addon needed : no
$regfile = "m8515.dat" ' specify the used micro
$sim
'REMOVE the above command for the real program !!
'$sim is used for faster simulation
'note : tested in PIN mode with 4-bit
'These settings are for the STK200 in PIN mode
'Connect only DB4 to DB7 of the LCD to the LCD connector of the STK D4-D7
'Connect the E-line of the LCD to A15 (PORTC.7) and NOT to the E line of the LCD connector
'Connect the RS, V0, GND and =5V of the LCD to the STK LCD connector
Dim A As Byte
Config Lcd = 16 * 2 'configure lcd screen
'other options are 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
' because it aint need the port pins !
Cls 'clear the LCD display
Wait 1
Wait 1
Wait 1
For A = 1 To 10
Wait 1 'wait a moment
For A = 1 To 10
Lcd "*" 'display this
Lcd "@" 'display this
Cursor On Blink 'show cursor
Display Off 'turn display off
Display On 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Fourth
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228 ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240 ' replace ? with number (0-7)
Cls 'select data RAM
_temp1 = 1 'value into ACC
REM BETTER USE LCDCMD
