File Import Project
Top  Previous  Next
This options is intended to import old BASCOM projects.
Your current project will be closed and you will get a file open dialog where you can select the old bascom source file.
All includes files found in your source will be added to the project file. At the moment this option simplifies working with old projects since it will create a BPJ project file that will contain all the used files.
Import Project shortcut: CTRL + I
