This library was sponsored by a customer.
The library supports the EADOGMXL240-7 in I2C mode.
The library supports all the usual graphical LCD commands.
' eadogxl240-7.bas
' (c) MCS Electronics 1995-2020
' Sample to demo the EADOGXL240-7 LCD in I2C mode
$regfile = "M328pdef.dat" ' the used chip
$crystal = 8000000 ' frequency used
$baud = 19200 ' baud rate
$hwstack = 40
$swstack = 40
$framesize = 40
Config Scl = Portc.5 ' we need to provide the SCL pin name
Config Sda = Portc.4 ' we need to provide the SDA pin name
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
Config Twi = 400000 'speed 400 KHz
I2cinit
$lib "glcdEADOGMXL240-7-I2C.lib" 'override the default lib with this special one
#if _build < 2078
Dim ___lcdrow As Byte , ___lcdcol As Byte
#endif
Config Graphlcd = Custom , Cols = 240 , Rows = 128 , Lcdname = "EADOGXL240-7"
Cls
Setfont Font8x8tt
'You can use locate but the columns have a range from 1-240
'When you want to show somthing on the LCD, use the LDAT command
Lcdat 1 , 1 , "11111111"
Lcdat 2 , 1 , "88888888"
Lcdat 12 , 64 , "MCS Electronics" , 1
Showpic 60 , 0 , Plaatje
Circle(30 , 30) , 20 , 255
Line(0 , 0) -(239 , 127) , 255 ' diagonal line
Line(0 , 127) -(239 , 0) , 255 ' diagonal line
$include "font8x8TT.font"
Plaatje:
$bgf "ks108.bgf" 'include the picture data
