Declares a subroutine.
DECLARE SUB TEST[( [BYREF/BYVAL] var as type)]
test |
Name of the procedure. |
Var |
Name of the variable(s). |
Type |
Type of the variable(s). Byte, Word, Integer, Long, Single or String. |
When BYREF or BYVAL is not provided, the parameter will be passed by reference.
Use BYREF to pass a variable by reference with its address.
Use BYVAL to pass a copy of the variable.
See the CALL statement for more details.
You must declare each function before writing the function or calling the function. And the declaration must match the function.
Bits are global and can not be passed with functions or subs.
'name : declare.bas
'purpose : demonstrate using declare
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
'Try a SUB without parameters
Declare Sub Test2
'the subprogram
Dim Ar(10) As Byte
For Bb = 1 To 10
Bb = 1
Call Teststr(bb , Sar(1))
Call Test2 'call sub
Test2 'or use without CALL
Bb = 1
Print Bb ; I ; W ; L ; S
'now pass an array
Testarray 2 , Ar(1)
Print "ar(1) = " ; Ar(1)
Print "ar(3) = " ; Ar(3)
Testvar Bb , I , I , I , S
$typecheck 'turn it back on
B1 = 3 'change value
End Sub
Print "No parameters"
End Sub
Local X As Byte
X = 5 'assign local
B = X
I = -1
W = 40000
L = 20000
S = "test"
End Sub
End Sub
Dl(b) = Dl(b) + "add"
End Sub
