CONFIG TIMER2
Top  Previous  Next
Configure TIMER2.
Syntax for the 8535
CONFIG TIMER2 = TIMER | PWM , ASYNC=ON |OFF,
PRESCALE = 1 | 8 | 32 | 64 | 128 | 256 | 1024 ,
COMPARE = CLEAR | SET | TOGGLE I DISCONNECT ,
PWM = ON | OFF ,
COMPARE PWM = CLEAR UP| CLEAR DOWN | DISCONNECT ,
CLEAR TIMER = 1|0
Syntax for the M103
CONFIG TIMER2 = COUNTER| TIMER | PWM ,
EDGE= FALLING |RISING,
PRESCALE = 1 | 8 | 64 | 256 | 1024 ,
PWM = ON | OFF ,
CLEAR TIMER = 1|0
The TIMER2 is an 8 bit counter.
It depends on the chip if it can work as a counter or not.
The syntax shown above must be on one line. Not all the options need to be selected.
Here is the effect of the various options.
EDGE
You can select whether the TIMER will count on the falling or rising edge. Only for COUNTER mode.
PRESCALE
The TIMER is connected to the system clock in this case. You can select the division of the system clock with this parameter.
Valid values are 1 , 8, 64, 256 or 1024
or
1 , 8, 32 , 64 , 256 or 1024 for the M103
Prescale can not be used in COUNTER mode.
The TIMER2 also has a compare registers
When the timer value matches a compare register, an action can be performed
COMPARE
The action can be:
SET will set the OC2 pin
CLEAR will clear the OC2 pin
TOGGLE will toggle the OC2 pin
DISCONNECT will disconnect the TIMER from output pin OC2
And the TIMER can be used in 8 bit PWM mode
You can specify if the counter must count UP or down after a match to the compare registers
COMPARE PWM
PWM compare mode.
Can be CLEAR UP or CLEAR DOWN
Dim W As Byte
Config Timer2 = Timer , ASYNC = 1 , Prescale = 128
On TIMER2 Myisr
ENABLE INTERRUPTS
ENABLE TIMER2
DO
LOOP
MYISR:
'get here every second with a 32768 Hz xtal
RETURN
'You can read or write to the timer with the COUNTER2 or TIMER2 variable
W = Timer2
Timer2 = W
