CONFIG TCPIP 2082 ENHANCED
Top  Previous  Next
This chip's can be found on various modules and shields but the Config Tcpip is always depending on the WIZNET chip.
Syntax W3100A
Syntax W5100
Syntax W5200
Syntax W5300
Syntax W5500
CONFIG TCPIP = NOINT , MAC = mac , IP = ip, SUBMASK = mask, GATEWAY = gateway, LOCALPORT= port, NOINIT= 0|1 [,TimeOut=tmOut] [,CHIP=W5500] [,SPI=spi] [,INT=imsg] [,CS=cs] [,NOUDP=noudp] [TXn= tx] [, RXn= rx]
Int
W5100,W5200,W5300 also support the NOINT option. This option will not use any  interrupt. The internal status array s_status will not be created and is not available either.
When you do use interrupts, the s_status array will contain the status of each socket. s_status(1) will contain the status of the first socket.
W5500 only supports the NOINT option.
MAC
Example : 00.00.12.34.56.78
IP
SUBMASK
GATEWAY
The gateway address you can determine with the IPCONFIG command at the command prompt :
C:\>ipconfig
Windows 2000 IP Configuration
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.0.3
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Use 192.168.0.1 in this case.
LOCALPORT
A word value that is assigned to the LOCAL_PORT internal variable. See also Getsocket.
TX
W3100A,W5100
For example, you want to assign 2048 bytes to each socket for transmission : TX = &B01010101
Since the transmission buffer size may be 8KB in total, you can split them up in 4 parts of 2048 bytes : 01.
When you want to use 1 socket with 8KB size, you would use : TX = &B11. You can use only 1 socket in that case : socket 0.
RX
W3100A,W5100
For example, you want to assign 2048 bytes to each socket for reception : RX = &B01010101
Since the receive buffer size may be 8KB in total, you can split them up in 4 parts of 2048 bytes : 01.
When you want to use 1 socket with 8KB size, you would use : RX = &B11. You can use only 1 socket in that case : socket 0.
TXn
W5200, W5300,w5500
The following values are possible :
Value
W5200,W5500
W5300
1
1 KB
1 KB
2
2 KB default
2 KB
4
4 KB
4 KB
8
8 KB
8 KB default
15
16 KB
15 KB
any other value between 1-64
invalid
size in KB
RXn
W5200,W5300,W5500
sockmem
W5300
Noinit
Make this option 1 when you want to configure the TCP, MAC, Subnetmask and GateWay dynamic. Noinit will only make some important settings and you need to use SETTCP in order to finish the setup.
TWI
W3100A only
Clock
W3100A only
Baseaddress
W3100A,W5100,W5300
See also: Adding XRAM with External Memory Interface
TimeOut
W3100A
CHIP
Specify W5500 for the W5500 chip. This chip has 8 sockets and only a SPI interface. This SPI interface supports high speed and blockmode.
SPI
This option is intended to be used with the W5100/W5200 chips. When you want to use the W5100  or W5200 in SPI mode, make this parameter value 1.
For normal AVR with multiple SPI such as M328PB you can specify SPI1
Example :
Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 4 , Noss = 0
'Init the spi pins
Spiinit
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.70 , Submask = 255.255.255.0 , Gateway = 192.168.1.1 , Localport = 1000 , Tx = $55 , Rx = $55 , Chip = W5100 , Spi = 1 , Cs = Portb.4
imsg
cs
noticeYou should use a normal port register. Do not use an extended address port like PORTL.
noudp
align
The W5300 has an align option. Align is ignored for all other chips.
The align modes :
0 - this will disable alignment. This will add a header packet for TCP data with the size. You must use TCPREADHEADER to read the actual data size. Socketstat will not return the actual data size. After you have determined there is data in the receive buffer, you must use TCPREADHEADER to get the actual size. You may only use TCPREADHEADER once since it will read 2 bytes from the receive buffer.
Since it will read from the receive buffer, you must empty the buffer with tcpread, after you have determined that there is data waiting. You must not call socketstat again before you have read all the pending data.
noticeAs all the samples show, the CONFIG TCPIP must be used in the main program. The CONFIG TCPIP should be used early as possible in your code. This is especially important for processors with multiple pages. (>64KB). The reason is that the configuration data is stored in flash and read with LPM instruction. LPM can only reach page 0.
W3100A
W5100
- When reading UDP, you need to use the UDPREADHEADER statement to read the UDP header. After reading the header, the peersize, peerport and peeraddress variables are set. You then should use the peersize variable to determine the number of bytes to retrieve. You must read all these bytes.
- The W5100 has a command to disconnect the socket in TCP/IP mode. It is named SOCKETDISCONNECT.
- The CLOSESOCKET statement has been renamed into SOCKETCLOSE. You can use both names.
The MCS web shop offers the WIZ810MJ ethernet module and the TCPADB5100 adapter board.
W5200
This Chip need  specific reset times before you can use config TCPIP (see example below).
It has been reported that when the RETRY_TIME and RETRY_COUNT registers are altered, sending UDP data can have a variable delay the first time the data will actually be sent.
W5300
The W5300 is a bus mode only version of the W5100 so read the comment above about the W5100 first
See also the W5300 examples in: Adding XRAM with External Memory Interface regarding base address.
W5500
The W5500 is a SPI only version of the W5100 so read the comment above about the W5100 first.
The W5500 chip has less pins and is smaller and simpler to use. It has 8 sockets instead of 4 and it has a faster SPI mode. It is similar to W5200.
For samples, use the W5200 samples and change CHIP to W5500.
The W5500 library has specific provision to be used in a boot loader.
WIZ810
REV 1.0 of the WIZ810 leaves the SPI_EN Pin floating (REV1.1 has an internal pulldown). When using REV1.0 in parallel mode, you will have to tie that pin to ground.
GETSOCKET , SOCKETCONNECT, SOCKETSTAT , TCPWRITE, TCPWRITESTR, TCPREAD, CLOSESOCKET , SOCKETLISTEN , SOCKETDISCONNECT , SETTCP , UDPREAD, UDPWRITE, UDPWRITESTR , UDPREADHEADER, TCPREADHEADER , TCPCHECKSUM, SNTP , , GETTCPREGS , SETTCPREGS
Syntax Example using W3100:
Now use PING at the command line to send a ping:
PING 192.168.0.8
Syntax Example using W5100
$regfile = "m88def.dat"                                     ' specify the used micro
$crystal = 8000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
$hwstack = 80                                               ' default use 32 for the hardware stack
$swstack = 128                                             ' default use 10 for the SW stack
$framesize = 80                                             ' default use 40 for the frame space
$lib "datetime.lbx"                                         ' this example uses date time routines
Print "Init TCP"                                           ' display a message
Enable Interrupts                                           ' before we use config tcpip , we need to enable the interrupts
Config Tcpip = Int1 , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.70 , Submask = 255.255.255.0 , Gateway = 192.168.1.1 , Localport = 1000 , Tx = $55 , Rx = $55 ,  Chip = W5100 , Spi = 1
Print "Init done"
Dim Var As Byte                                             ' for i2c test
Dim Ip As Long                                             ' IP number of time server
Dim Idx As Byte                                             ' socket number
Dim Lsntp As Long                                           ' long SNTP time
Print "SNTP demo"
Ip = Maketcp(64.90.182.55 )                                 ' assign IP num NIST time.nist.gov  port 37
Print "Connecting to : " ; Ip2str(ip)
'we will use Dutch format
Idx = Getsocket(idx , Sock_dgram , 5000 , 0)               ' get socket for UDP mode, specify port 5000
  Waitms 5000
  Lsntp = Sntp(idx , Ip)                                   ' get time from SNTP server
'  Print Idx ; Lsntp
Example for using W5200 Chip on a WIZ820io module with ATXMEGA:
Hardware connections:
 WIZ820io [SCLK]         <-----> ATXMEGA128A1 PortC.7 [SCK]
 WIZ820io [MOSI]         <-----> ATXMEGA128A1 PortC.5 [MOSI]
 WIZ820io [MISO]         <-----> ATXMEGA128A1 PortC.6 [MISO]
 WIZ820io [nSS]         <-----> ATXMEGA128A1 PortC.4 [SS]
 WIZ820io [nReset]<-----> ATXMEGA128A1 PortC.2
 WIZ820io [nINT]         <-----> ATXMEGA128A1 PortC.3
Config Pinc.2 = Output
W5200_nreset Alias Portc.2
Set W5200_nreset
Config Pinc.3 = Input
W5200_nint Alias Portc.3
Reset the WIZ820io Module:
Reset W5200_nreset
Waitms 1
Set W5200_nreset
Waitms 150
Config Tcpip = Noint , _
          Mac = 0.11.22.33.44.55 , _
          Ip = 192.168.1.254 , _
          Submask = 255.255.255.0 , _
          Gateway = 192.168.1.1 , _
          Localport = 80 , _
          Chip = W5200 , _
          Spi = Spic , _
          Cs = Portc.4
PING 192.168.1.254
Example for using W5300 Chip:
PING 192.168.1.253
Example for using W5500 Chip:
'name                     : sntp_W5500.bas   RFC 2030
'copyright                : (c) 1995-2020, MCS Electronics
'purpose                  : test SNTP() function
'micro                    : xMega128A1
'suited for demo          : no, needs library only included in the full version
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = 64                                               ' default use 32 for the hardware stack
$swstack = 128                                             'default use 10 for the SW stack
$framesize = 64                                             'default use 40 for the frame space
'configure the systemclock
'configure UART
Config Spie = Hard , Master = Yes , Mode = 0 , Clockdiv = Clk32 , Data_order = Msb , Ss = Auto
'SPI on Port E is used
'portx.7 - SCK
'portx.6 - MISO
'portx.5 - MOSI
'portx.4 - SS
Waitms 1000
Print "Init , set IP to 192.168.1.88"                       ' display a message
Config Tcpip = Noint , Mac = 12.128.12.34.56.78 , Ip = 192.168.1.88 , Submask = 255.255.255.0 , Gateway = 192.168.1.1 , Localport = 1000 , Chip = W5500 , Spi = Spie , Cs = Porte.4
Print "Init Done"
$lib "datetime.lbx"                                         'this example uses date time routines
Print "SNTP demo"
Ip = Maketcp(129.6.15.30 )                                 'assign IP num NIST time.nist.gov  port 37
Config Date = Dmy , Separator = Minus
  Waitms 5000
