CONFIG LCDBUS
Top  Previous  Next
Configures the LCD data bus and overrides the compiler setting.
CONFIG LCDBUS = constant
Constant
4 for 4-bit operation, 8 for 8-bit mode (default)
Use this statement together with the $LCD = address statement.
When you use the LCD display in the bus mode the default is to connect all the data lines. With the 4-bit mode, you only have to connect data lines d7-d4.
CONFIG LCD
'                 (c) 1995-2020 MCS Electronics
'  file: LCD.BAS
'  demo: LCD, CLS, LOWERLINE, SHIFTLCD, SHIFTCURSOR, HOME
'        CURSOR, DISPLAY
'note : tested in bus mode with 4-bit on the STK200
'LCD   -   STK200
'D4         D4
'D5         D5
'D6         D6
'D7         D7
'WR         WR
'E          E
'RS         RS
'+5V        +5V
'GND        GND
'V0         V0
'   D0-D3 are not connected since 4 bit bus mode is used!
$regfile = "8515def.dat"
$lcd = &HC000
$lcdrs = &H8000
Config Lcdbus = 4
Dim A As Byte
Config Lcd = 16x2                                         'configure lcd screen
'other options are 16 * 2 , 16 * 4 and 20 * 4, 20 * 2 , 16 * 1a
'       use this with uP with external RAM and/or ROM
'       because it aint need the port pins !
Cls                                                       'clear the LCD display
Lcd "Hello world."                                         'display this at the top line
Wait 1
Lowerline                                                 'select the lower line
Wait 1
Lcd "Shift this."                                         'display this at the lower line
Wait 1
For A = 1 To 10
Shiftlcd Right                                         'shift the text to the right
Wait 1                                                   'wait a moment
For A = 1 To 10
Shiftlcd Left                                           'shift the text to the left
Locate 2 , 1                                               'set cursor position
Lcd "*"                                                   'display this
Shiftcursor Right                                         'shift the cursor
Lcd "@"                                                   'display this
Home Upper                                                 'select line 1 and return home
Lcd "Replaced."                                           'replace the text
Cursor Off Noblink                                         'hide cursor
Cursor On Blink                                           'show cursor
Display Off                                               'turn display off
Display On                                                 'turn display on
Thirdline
Lcd "Line 3"
Fourthline
Lcd "Line 4"
Home Third                                                 'goto home on line three
Home Fourth
Home F                                                     'first letteer also works
Locate 4 , 1 : Lcd "Line 4"
Wait 1
Deflcdchar 1 , 225 , 227 , 226 , 226 , 226 , 242 , 234 , 228       ' replace ? with number (0-7)
Deflcdchar 0 , 240 , 224 , 224 , 255 , 254 , 252 , 248 , 240       ' replace ? with number (0-7)
Cls                                                       'select data RAM
Lcd Chr(0) ; Chr(1)                                       'print the special character
_temp1 = 1                                                 'value into ACC
!rCall _write_lcd                                           'put it on LCD
