CONFIG ERROR
CONFIG ERROR
Top  Previous  Next
Instructs the compiler to ignore one or more errors.
CONFIG ERROR=ignore, err=ignore [err1=ignore]
In some situations you might want to ignore an error. For example if a new version adds a certain check that was not available in a previous version you will get errors. If you ignore the error, the code will compile without errors. This will not work in any situation. Some errors can not be ignored. You should never use this option for a finished product.
Config Error = Ignore , 369 = Ignore
Lbl:
Dim Lbl As Word ' this would generate an error 369 without the ignore !!!
