CONFIG DP
CONFIG DP
Top  Previous  Next
This option sets the character used for the decimal point for singles and fusing.
CONFIG DP= "dp"
The decimal point is a dot (.) by default. The STR() and FUSING functions convert a single into a string. The fraction is separated by a dot. In a number of counties the comma is used as a separator.
Old Syntax:
Valid options are : CONFIG DP = "."  and CONFIG DP = ","
New preferred Syntax:
Valid options are : CONFIG DP = DOT  and CONFIG DP = COMMA
This options only sets the character for str() and fusing for singles. In your code you still need to code with a dot :  var = 1234.333
CONFIG DP = ","
Dim s as single
S = 1234.56
print s
