Configures the delay time for the DEBOUNCE statement.
CONFIG DEBOUNCE = time
| Time | A numeric constant which specifies the delay time in mS. The maximum delay is 65535. |
When debounce time is not configured, 25 mS will be used as a default.
'name : deboun.bas
'copyright : (c) 1995-2025, MCS Electronics
'purpose : demonstrates DEBOUNCE
'micro : Mega48
'suited for demo : yes
'commercial addon needed : no
Config Debounce = 30 'when the config statement is not used a default of 25mS will be used
'Debounce Pind.0 , 1 , Pr 'try this for branching when high(1)
Debounce Pind.0 , 0 , Pr , Sub
' ^----- label to branch to
' ^---------- Branch when P1.0 goes low(0)
' ^---------------- Examine P1.0
'When Pind.0 goes low jump to subroutine Pr
'Pind.0 must go high again before it jumps again
'to the label Pr when Pind.0 is low
Debounce Pind.0 , 1 , Pr 'no branch
Debounce Pind.0 , 1 , Pr 'will result in a return without gosub
Pr:
Print "PIND.0 was/is low"
