CONFIG DATE
Top  Previous  Next
Configure the Format of the Date String for Input to and Output from BASCOM – Date functions
CONFIG DATE = DMY , Separator = char
DMY
The Day, month and year order. Use DMY, MDY or YMD.
Char
The character used to separate the day, month and year.
Old syntax :  / , - or . (dot).
Preferred new syntax : MINUS, SLASH or DOT.
Example:
Config Date = DMY, SEPARATOR=MINUS
The following table shows the common formats of date and the associated statements.
Country
Format
Statement
American
mm/dd/yy
Config Date = MDY, Separator = SLASH
ANSI
yy.mm.dd
Config Date = YMD, Separator = DOT
Britisch/French
dd/mm/yy
Config Date = DMY, Separator = SLASH
German
dd.mm.yy
Config Date = DMY, Separator = DOT
Italian
dd-mm-yy
Config Date = DMY, Separator = MINUS
Japan/Taiwan
yy/mm/dd
Config Date = YMD, Separator = SLASH
USA
mm-dd-yy
Config Date = MDY, Separator = MINUS
When you live in Holland you would use :
CONFIG DATE = DMY, separator = MINUS
This would print 24-04-02 for 24 November 2002.
When you line in the US, you would use :
CONFIG DATE = MDY , separator = SLASH
This would print 04/24/02 for 24 November 2002.
CONFIG CLOCK , DATE TIME functions , DayOfWeek , DayOfYear , SecOfDay , SecElapsed , SysDay , SysSec , SysSecElapsed , Time , Date
'name                     : megaclock.bas
'copyright                : (c) 1995-2020, MCS Electronics
'purpose                  : shows the new TIME$ and DATE$ reserved variables
'micro                    : Mega103
$regfile = "m103def.dat"                                   ' specify the used micro
$crystal = 4000000                                         ' used crystal frequency
$baud = 19200                                               ' use baud rate
'[configure LCD]
$lcd = &HC000                                               'address for E and RS
$lcdrs = &H8000                                             'address for only E
Config Lcd = 20 * 4                                         'nice display from bg micro
Config Lcdbus = 4                                           'we run it in bus mode and I hooked up only db4-db7
Config Lcdmode = Bus                                       'tell about the bus mode
'[now init the clock]
Config Date = Mdy , Separator = SLASH                           ' ANSI-Format
Config Clock = Soft                                         'this is how simple it is
'The format is MM/DD/YY
Date$ = "11/11/00"
'You may not use 1:2:3 !! adding support for this would mean overhead
Time$ = "02:20:00"
'clear the LCD display
Cls
Home                                                     'cursor home
Lcd Date$ ; "  " ; Time$                                 'show the date and time
_day = 1
