CONFIG ADC
Top  Previous  Next
Configures the A/D converter.
CONFIG ADC = single, PRESCALER = AUTO, REFERENCE = opt
ADC
PRESCALER
A numeric constant for the clock divider. Use AUTO to let the compiler generate the best value depending on the XTAL
REFERENCE
The options depend on the used micro. Some chips like the M163 have additional reference options. In the definition files you will find : ADC_REFMODEL = x
This specifies which reference options are available. The possible values are listed in the table below.
Chip
Modes
ADC_REFMODEL
2233,4433,4434,8535,m103,m603, m128103
OFF
AVCC
0
m165, m169, m325,m3250, m645,   m6450, m329,m3290, m649, m6490,m48,m88,m168
OFF
AVCC
INTERNAL or INTERNAL_1.1
1
tiny15,tiny26
AVCC
OFF
INTERNAL
INTERNALEXTCAP
2
tiny13
AVCC
INTERNAL
3
tiny24,tiny44,tiny85
AVCC
EXTERNAL or OFF
4
m164,m324,m644,m640,m1280, m1281,m2561,m2560
AREF or OFF
AVCC
INTERNAL1.1
INTERNAL_2.56
5
tiny261,tiny461,tiny861, tiny25,tiny45,tiny85
AVCC
EXTERNAL or OFF
INTERNAL_1.1
INTERNAL_2.56_NOCAP
INTERNAL_2.56_EXTCAP
7
CAN128, PWM2_3,USB1287, m128, m16, m163, m32, m323, m64
AREF or OFF
AVCC
INTERNAL or INTERNAL_2.56
8
You may also use VALUE=value
When you use VALUE=value, you may specify any value. The disadvantage is that when you port your code from one chip to another it will not work.
While the AREF, AVCC, etc. are all converter to the right settings, the value can not be converted.
The AD converter is started automatic when you use the CONFIG ADC command.
You can use STOP ADC and START ADC to disable and enable the power of the AD converter.
The GETADC() function is intended to be used with the SINGLE running mode. This means that each time you call GETADC(), a conversion is started. If you use the free running mode, you need to retrieve the value from the AD converter yourself. For example by reading the internal ADC word variable.
GETADC , CONFIG ADCx
'name                     : adc.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demonstration of GETADC() function for 8535 or M163 micro
'micro                    : Mega163
'use in simulator         : possible
' Getadc() will also work for other AVR chips that have an ADC converter
$regfile = "m163def.dat"                                   ' we use the M163
$crystal = 4000000
$swstack = 10                                               'default use 10 for the SW stack
$framesize = 40                                             'default use 40 for the frame space
'configure single mode and auto prescaler setting
'The single mode must be used with the GETADC() function
'The prescaler divides the internal clock by 2,4,8,16,32,64 or 128
'Because the ADC needs a clock from 50-200 KHz
'The AUTO feature, will select the highest clockrate possible
'Now give power to the chip
Start Adc  ' NOT required since it will start automatic
'With STOP ADC, you can remove the power from the chip
'Stop Adc
Dim W As Word , Channel As Byte
Channel = 0
'now read A/D value from channel 0
W = Getadc(channel)
Print "Channel " ; Channel ; " value " ; W
Incr Channel
If Channel > 7 Then Channel = 0
'The new M163 has options for the reference voltage
'For this chip you can use the additional param :
'Config Adc = Single , Prescaler = Auto, Reference = Internal
'The reference param may be :
'OFF      : AREF, internal reference turned off
'AVCC     : AVCC, with external capacitor at AREF pin
'INTERNAL : Internal 2.56 voltage reference with external capacitor ar AREF pin
'Using the additional param on chip that do not have the internal reference will have no effect.
