CONFIG 1WIRE
Top  Previous  Next
Configure the pin to use for 1WIRE statements and override the compiler setting.
CONFIG 1WIRE = pin [, extended=0|1]
Pin
The port pin to use such as PORTB.0
extended
An optional constant value of 0 or 1. This is an optional parameter
The CONFIG 1WIRE statement overrides the compiler setting. It is the preferred that you use it. This way the setting is stored in your source code.
You can configure only one pin for the 1WIRE statements because the idea is that you can attach multiple 1WIRE devices to the 1WIRE bus.
You can however use multiple pins and thus multiple busses. All 1wire commands and functions need the port and pin in that case. A CONFIG 1WIRE statement is not need in that case either.
The 1wire commands and function will automatically set the DDR and PORT register bits to the proper state. You do not need to bring the pins into the right state yourself.
It is important that you use a pull up resistor of 4K7 ohm on the 1wire pin(for 5V VCC). The pull up resistor of the AVR is not sufficient.
Also notice that some 1wire chips also need +5V. 1 wire is just marketing since you need GND anyway. The least is 2 wires and typical you need 3 wires.
Extended
The extended option is only required when you use multiple busses/pins and if these pins mix normal and extended addresses.
Let's clear that up. When the 1wire code was written in 1995 all the port addresses were normal I/O addresses. These are addresses that fit in the I/O space (address < &H60).  To save code, register R31 was cleared in the library and the port register was passed in R30.
When Atmel introduced the extended I/O registers with address >&HFF, it was possible to set R31 to a fixed value when the user port was an extended I/O address.
But when you want to mix the addresses, there is no other way then to pass the word address of the I/O register to the library code.
And that is exactly what EXTENDED=1 will do. It will use more code. This support was written for a customer that already made his PCB's. We do advise to use the same port when you use multiple pins.
ATMEGA128 PORTF
The ATMEGA128 PORTF is split up. Normally, the DDR, PIN and PORT registers are in the same order.
For example : PORTB        = &H18 , DDRB        = &H17 and PINB = &H16
But PORTF in the MEGA128 is different :  PINF        = &H00  , PORTF = &H62 , DDRF = &H61
You need a special library named M128-1wire-PortF.lib for this processor and port. This library is fixed to portF
1WRESET , 1WREAD , 1WWRITE , 1WIRECOUNT , 1WRESET , 1WSEARCHFIRST , 1WSEARCHNEXT
'name                     : 1wire.bas
'copyright                : (c) 1995-2025, MCS Electronics
'purpose                  : demonstrates 1wreset, 1wwrite and 1wread()
$regfile = "m48def.dat"
$crystal = 8000000
$swstack = 10                                               'default use 10 for the SW stack
$framesize = 40                                             'default use 40 for the frame space
'when only bytes are used, use the following lib for smaller code
$lib "mcsbyte.lib"
Config 1wire = Portb.0                                     'use this pin
Wait 1
1wreset                                                   'reset the device
Print Err                                               'print error 1 if error
1wwrite &H33                                             'read ROM command
For I = 1 To 8
  Ar(i) = 1wread()                                       'place into array
'You could also read 8 bytes a time by unremarking the next line
'and by deleting the for next above
'Ar(1) = 1wread(8)                                           'read 8 bytes
For I = 1 To 8
  Print Hex(ar(i));                                     'print output
Print                                                   'linefeed
'NOTE THAT WHEN YOU COMPILE THIS SAMPLE THE CODE WILL RUN TO THIS POINT
'THIS because of the DO LOOP that is never terminated!!!
'New is the possibility to use more than one 1 wire bus
'The following syntax must be used:
For I = 1 To 8
Ar(i) = 0                                                 'clear array to see that it works
1wreset Pinb , 2                                           'use this port and  pin for the second device
1wwrite &H33 , 1 , Pinb , 2                                 'note that now the number of bytes must be specified!
'1wwrite Ar(1) , 5,pinb,2
'reading is also different
Ar(1) = 1wread(8 , Pinb , 2)                               'read 8 bytes from portB on pin 2
For I = 1 To 8
Print Hex(ar(i));
'you could create a loop with a variable for the bit number !
For I = 0 To 3                                             'for pin 0-3
1wreset Pinb , I
1wwrite &H33 , 1 , Pinb , I
Ar(1) = 1wread(8 , Pinb , I)
For A = 1 To 8
  Print Hex(ar(a));
Print
Xmega Example
'name                     : XM128-1wire.bas
'micro                    : Xm128A1
'suited for demo          : no
' pull-up of 4K7 required to VCC from Portb.0
' DS2401 serial button connected to Portb.0
$regfile = "xm128a1def.dat"
$crystal = 32000000
$lib "xmega.lib" : $external _xmegafix_clear : $external _xmegafix_rol_r1014
$swstack = 32                                               'default use 10 for the SW stack
$framesize = 32                                             'default use 40 for the frame space
'configure the systemclock
'configure UART
'configure 1wire pin
Print "start"
A = 1wirecount()
Print A ; " devices found"
'get first
Ar(1) = 1wsearchfirst()
For I = 1 To 8                                             'print the number
Print Hex(ar(i));
Print
  'Now search for other devices
  Ar(1) = 1wsearchnext()                                   ' get next device
  For I = 1 To 8
  Print Hex(ar(i));
  Print
Loop Until Err = 1
Waitms 2000
'  Ar(1) = 1wread(8)    you can use this instead of the code below
For I = 1 To 8
For I = 1 To 8
Print                                                     'linefeed
Waitms 1000
