Clear buffers to preset values.
(This is similar to CLS)
Clear_B C,S,T
C |
Clear Color buffer. Setting this bit to 1 will clear the color buffer of the FT800 to the preset value. Setting this bit to 0 will maintain the color buffer of the FT800 with an unchanged value. The preset value is defined in command ClearColorRGB for the RGB channel and ClearColorA for the alpha channel. |
S |
Clear Stencil buffer. Setting this bit to 1 will clear the stencil buffer of the FT800 to the preset value. Setting this bit to 0 will maintain the stencil buffer of the FT800 with an unchanged value. The preset value is defined in command ClearStencil. |
T |
Clear Tag buffer. Setting this bit to 1 will clear the tag buffer of the FT800 to the preset value. Setting this bit to 0 will maintain the tag buffer of the FT800 with an unchanged value. The preset value is defined in command ClearTag. |
The scissor test and the buffer write masks affect the operation of the clear. Scissor limits the cleared rectangle, and the buffer write masks limit the affected buffers.
The state of the alpha function, blend function, and stenciling do not affect the clear.
ClearColorA, ClearStencil, ClearTag, ClearColorRGB
' Pseudocode
' To Clear the LCD to bright blue:
ClearColorRGB 0, 0, 255
Clear_B 1, 0, 0
' Pseudocode
' To clear part of the screen to gray, part to blue using scissor rectangles:
ClearColorRGB 100, 100, 100
Clear_B 1, 1, 1
ScissorScize 30, 120
Clear_B 1, 1, 1
