Changes the baud rate for the hardware UART.
BAUD = var
Syntax Software UART
BAUD #x , const
Var |
The baud rate that you want to use. |
X |
The channel number of the software UART. |
Const |
A numeric constant for the baud rate that you want to use. |
Do not confuse the BAUD statement with the $BAUD compiler directive.
And do not confuse $CRYSTAL and CRYSTAL
$BAUD overrides the compiler setting for the baud rate while BAUD will change the current baud rate.
So $BAUD is a global project setting in your source code while BAUD will change the baud rate during run time.
You could use BAUD to change the baud rate during run time after the user changes a setting.
BAUD = ... will work on the hardware UART.
BAUD #x, yyyy will work on the software UART.
When you use a software UART and change the baud rate at run time using BAUD, you must set the baud rate after the OPEN statements as well.
When you do not use BAUD, there is no need to set it. So for example :
Open "COMC.1:9600,8,N,1" For Output As #1
print #1 , "this is a test 9600" 'no need for BAUD since 1 baud rate is used
But when BAUD is changed :
baud #1 , 9600 'we need to set it since we change baud at run time
baud #1 , 115200
print #1 , "this is a test 115200"
$regfile = "m48def.dat"
$crystal = 4000000
$baud = 19200
Print "Hello"
'Now change the baud rate in a program
Baud = 9600
Print "Did you change the terminal emulator baud rate too?"
