BASCOM Editor Keys
BASCOM Editor Keys
Top  Previous  Next
Key
LEFT ARROW
One character to the left
RIGHT ARROW
One character to the right
UP ARROW
One line up
DOWN ARROW
One line down
HOME
To the beginning of a line
END
To the end of a line
PAGE UP
Up one window
PAGE DOWN
Down one window
CTRL+LEFT
One word to the left
CTRL+RIGHT
One word to the right
CTRL+HOME
To the start of the text
CTRL+END
To the end of the text
CTRL+ Y
Delete current line
INS
Toggles insert/over strike mode
F1
Help (context sensitive)
F2
Run simulator
F3
Find next text
F4
Send to chip (run flash programmer)
F5
Run
F7
Compile File
F8
Step
F9
Set breakpoint
F10
Run to
F11
Collapse Code Toggle Sub/Function
SHIFT+F11 or
CTRL+ENTER
Collapse Code Toggle current block
CTRL+F7
Syntax Check
CTRL+F
Find text
CTRL+G
Go to line
CTRL+K+x
Toggle bookmark. X can be 1-8
CTRL+L
LCD Designer
CTRL+M
File Simulation
CTRL+N
New File
CTRL+O
Load File
CTRL+P
Print File
CTRL+Q+x
Go to Bookmark. X can be 1-8
CTRL+R
Replace text
CTRL+S
Save File
CTRL+T
Terminal emulator
CTRL+P
Compiler Options
CTRL+W
Show result of compilation
CTRL+X
Cut selected text to clipboard
CTRL+Z
Undo last modification
SHIFT+CTRL+Z
Redo last undo
CTRL+INS
Copy selected text to clipboard
SHIFT+INS
Copy text from clipboard to editor
CTRL+SHIFT+J
Indent Block
CTRL+SHIFT+U
Unindent Block
Select text
Hold the SHIFT key down and use the cursor keys to select text. or keep the left mouse key pressed and drag the cursor over the text to select.
CTRL+SPACE
Code help.
SHIFT + MOUSE
Hover on indention lines to see to which group they belong.
Hover on an element in your code to get info about that element.
CTRL+BACKSPACE
Jump back
CTRL+CLICK
Hold the CTRL key down and hover with the mouse till an element is underlined like an URL. Click the left mouse to jump to the implementation.
