BASAVR
| Index
#AUTOCODE
#IF ELSE ENDIF
$ASM
$BAUD
$BAUD1
$BGF
$BIGSTRINGS
$BOOT
$CRYSTAL
$DATA
$DBG
$DEFAULT
$EEPLEAVE
$EEPROM
$EEPROMHEX
$EEPROMSIZE
$END ASM
$EXTERNAL
$FRAMESIZE
$HWSTACK
$INC
$INCLUDE
$INITMICRO
$LCD
$LCDPUTCTRL
$LCDPUTDATA
$LCDRS
$LCDVFO
$LIB
$LOADER
$LOADERSIZE
$MAP
$NOCOMPILE
$NOINIT
$NORAMCLEAR
$PROG
$PROGRAMMER
$PROJECTTIME
$REGFILE
$RESOURCE
$ROMSTART
$SERIALINPUT
$SERIALINPUT1
$SERIALINPUT2LCD
$SERIALOUTPUT
$SERIALOUTPUT1
$SIM
$SWSTACK
$TIMEOUT
$TINY
$WAITSTATE
$XA
$XRAMSIZE
$XRAMSTART
- 1 -
1WIRECOUNT
1WIRESEARCHNEXT
1WREAD
1WRESET
1WSEARCHFIRST
1WVERIFY
1WWRITE
- A -
ABS
ACOS
Adding XRAM
Additional Hardware
ADR
ADR2
ALIAS
AN
Application Notes
ARRAY
ASC
ASCII chart
ASIN
Assembler mnemonics
AT_EMULATOR
AT86RF401
AT90CAN128
AT90PWM2-3
AT90S1200
AT90S2313
AT90S2323
AT90S2333
AT90S2343
AT90S4414
AT90S4433
AT90S4434
AT90S8515
AT90S8535
AT90USB162
ATMEGA103
ATMEGA128
ATMEGA16
ATMEGA161
ATMEGA162
ATMEGA163
ATMEGA164P
ATMEGA165
ATMEGA168
ATMEGA169
ATMEGA2560
ATMEGA2561
ATMEGA32
ATMEGA323
ATMEGA324P
ATMEGA325
ATMEGA329
ATMEGA406
ATMEGA48
ATMEGA603
ATMEGA64
ATMEGA640
ATMEGA644P
ATMEGA645
ATMEGA649
ATMEGA8
ATMEGA8515
ATMEGA8535
ATMEGA88
ATN
ATN2
Attaching an LCD Display
ATtiny12
ATtiny13
ATtiny15
ATtiny22
ATtiny2313
ATtiny24
ATtiny25
ATtiny26
ATtiny261
ATtiny44
ATtiny45
ATtiny461
ATtiny84
ATtiny85
ATtiny861
AVR Internal Hardware
AVR Internal Hardware Port B
AVR Internal Hardware Port D
AVR Internal Hardware Watchdog timer
AVR Internal Registers
AVR-DOS File System
- B -
BASCOM Editor Keys
BASE64DEC
BASE64ENC
BAUD
BAUD1
BCCALL
BCD
BCDEF
BCINIT
BCRESET
BIN
BIN2GRAY
BINVAL
BIT
BITS
BITWAIT
BLOAD
BOX
BOXFILL
BSAVE
BUFSPACE
BYTE
BYVAL
- C -
CALL
CASE
Changes compared to BASCOM-8051
CHARPOS
CHECKSUM
CHR
CIRCLE
CLEAR
CLOCKDIVISION
CLOSE
Close Project
CLOSESOCKET
CLS
Compact FlashCard Driver
CONFIG
CONFIG 1WIRE
CONFIG ACI
CONFIG ADC
CONFIG ADCx
CONFIG ATEMU
CONFIG CLOCK
CONFIG CLOCKDIV
CONFIG COM1
CONFIG COM2
CONFIG COMx
CONFIG DAC
CONFIG DACA
CONFIG DACB
CONFIG DATE
CONFIG DCF77
CONFIG DEBOUNCE
CONFIG DMXSLAVE
CONFIG EEPROM
CONFIG EXTENDED_PORT
CONFIG GRAPHLCD
CONFIG HITAG
CONFIG I2CDELAY
CONFIG I2CSLAVE
CONFIG INPUT
CONFIG INTx
CONFIG KBD
CONFIG KEYBOARD
CONFIG LCD
CONFIG LCDBUS
CONFIG LCDMODE
CONFIG LCDPIN
CONFIG OSC
CONFIG PORT
CONFIG PRINT
CONFIG PRINTBIN
CONFIG PRIORITY
CONFIG PS2EMU
CONFIG RC5
CONFIG SCL
CONFIG SDA
CONFIG SERIALIN
CONFIG SERIALOUT
CONFIG SERVOS
CONFIG SHIFTIN
CONFIG SINGLE
CONFIG SPI
CONFIG SYSCLOCK
CONFIG TCPIP
CONFIG TIMER0
CONFIG TIMER1
CONFIG TIMER2
CONFIG TWI
CONFIG TWISLAVE
CONFIG USB
CONFIG WAITSUART
CONFIG WATCHDOG
CONFIG X10
CONFIG XRAM
CONST
Constants
CONTENTS
COS
COSH
COUNTER0 and COUNTER1
CPEEK
CPEEKH
CRC16
CRC16UNI
CRC32
CRC8
CRYSTAL
CURSOR
custom designs
- D -
DATA
DATE
DATE$
DATETIME
DAYOFWEEK
DAYOFYEAR
DBG
DCF77TIMEZONE
DEBOUNCE
DEBUG
DECLARE FUNCTION
DECLARE SUB
DECR
DEFBIT
DEFINT
DEFLCDCHAR
DEFLNG
DEFSNG
DEFWORD
DEFxxx
DEG2RAD
DELAY
DIM
DIR
DISABLE
DISKFREE
DISKSIZE
DISPLAY
DO
DOUBLE
DOWNTO
DriveCheck
DriveGetIdentity
DriveInit
DriveReadSector
DriveReset
DriveWriteSector
DTMFOUT
- E -
ECHO
Edit Collapse
Edit Collapse All
Edit Copy
Edit Cut
Edit Indent Block
Edit Insert Character
Edit Outdent Block
Edit Paste
Edit Proper Indent
Edit Redo
Edit Remark Block
Edit Select All
Edit UnCollapse All
Edit Undo
Elektor CF-Interface
ELSE
EM4095
ENABLE
ENCODER
END
END IF
END SELECT
EOF
ERAM
Error Codes
EUROTIMEDATE
EXIT
EXP
EXTENDED I2C
- F -
File Close
File Exit
File export HTML
File export to RTF
File Import Project
File New
File New Project
File Open
File Print
File Print Preview
File Save
File Save As
File Save Project
FILEATTR
FILEDATE
FILEDATETIME
FILELEN
FILETIME
FIX
FLIP
FLUSH
FM24C16
FM25C256
Font Editor
FOR
FORMAT
FOR-NEXT
FOURTHLINE
FP_TRIG
FRAC
FREEFILE
FUNCTION
FUSING
- G -
GET
GETADC
GETATKBD
GETATKBDRAW
GETDSTIP
GETDSTPORT
GETKBD
GETRC
GETRC5
GETSOCKET
GETTCPREGS
GLCD
GLCDCMD
GLCDDATA
GLCDSED
GOSUB
GOTO
GRAY2BIN
- H -
Help About
Help Index
Help Knowledge Base
Help MCS Forum
Help MCS Shop
Help On BASCOM
Help Support
Help Update
HEX
HEXVAL
HIGH
HIGHW
HOME
- I -
I2C TWI Slave
I2C_TWI
I2CINIT
I2CRBYTE
I2CRECEIVE
I2CSEND
I2CSLAVE
I2CSTART
I2CSTOP
I2CSTOP: I2CRBYTE: I2CWBYTE
I2CWBYTE
I2START
IDE
IDLE
IF
IF-THEN-ELSE-END IF
INCR
INDEX
INITFILESYSTEM
INITLCD
INKEY
INP
INPUT
INPUTBIN
INPUTHEX
Installation of BASCOM
INSTR
INT
INTEGER
IP2STR
ISCHARWAITING
- K -
KAMPROG
Keyword Reference
KILL
- L -
Language Fundamentals
LCASE
LCD
LCD RGB-8 Converter
LCD4.LIB
LCD4BUSY
LCD4E2
LCDAT
LCDCONTRAST
LCD-EPSON
LEFT
LEN
LINE
LINE INPUT
LINEINPUT
LOAD
LOADADR
LOADLABEL
LOADWORDADR
LOC
LOCAL
LOCATE
LOF
LOG
LOG10
LONG
LOOKDOWN
LOOKUP
LOOKUPSTR
LOOP
LOW
LOWERLINE
LTRIM
- M -
MACRO
MAKEBCD
MAKEDEC
MAKEINT
MAKEMODBUS
MAKETCP
MAX
MCS Bootloader
MCSBYTE
MCSBYTEINT
MEMCOPY
Memory usage
MID
MIN
Mixing ASM and BASIC
mkII
- N -
NBITS
New CF-Card Drivers
New IDE
New PC
Newbie problems
NEXT
- O -
ON INTERRUPT
ON VALUE
OPEN
Open Project
Options
Options Communication
Options Compiler Defaults
Options Compiler Settings
Options Editor
Options Editor Font
Options IDE
Options Programmer
Options Simulator
OUT
- P -
PCF8533
PDF viewer
PEEK
POKE
POPALL
POWER
POWER MODE
Power Up
POWERDOWN
POWERSAVE
PRINT
PRINTBIN
Program Development Order
Project Assemble
Project Compile
Project Flow Dependency
Project Output
Project Send to Chip
Project Show Result
Project Simulate
Project Syntax Check
PS2MOUSE_EMULATOR
PS2MOUSEXY
PSET
PULSEIN
PULSEOUT
PUSHALL
PUT
- Q -
QUOTE
- R -
RAD2DEG
RC5SEND
RC5SENDEXT
RC6SEND
READ
READEEPROM
READHITAG
READMAGCARD
REM
Resellers
Reserved Words
RESET
RESTORE
RETURN
RIGHT
RND
ROTATE
ROUND
RTRIM
Running BASCOM
- S -
Save Project As
Search Find
Search Find in Files
Search Find Next
Search Goto
Search Goto Bookmark
Search Next Bookmark
Search Next Error
Search Previous Bookmark
Search Replace
Search Toggle Bookmark
SECELAPSED
SECOFDAY
SEEK
SELECT
SELECT-CASE-END SELECT
SENDSCAN
SENDSCANKBD
SERIN
SEROUT
SET
SETFONT
SETIPPROTOCOL
SETTCP
SETTCPREGS
SGN
SHIFT
SHIFTCURSOR
SHIFTIN
SHIFTLCD
SHIFTOUT
SHOWPIC
SHOWPICE
SIN
SINGLE
SINH
SOCKETCONNECT
SOCKETLISTEN
SOCKETSTAT
SONYSEND
SOUND
SPACE
SPC
SPIIN
SPIINIT
SPIMOVE
SPIOUT
SPISLAVE
SPLIT
SQR
START
STCHECK
STEP
STK500 Programmer
STOP
STR
STRING
SUB
Supported Programmers
SWAP
SYSDAY
SYSSEC
SYSSECELAPSED
- T -
TAN
TANH
TCP/IP
TCPCHECKSUM
TCPIP
TCPREAD
TCPWRITE
TCPWRITESTR
THEN
THIRDLINE
TIME
TIME$
TIMER0
TIMER1
Tips and tricks
TOGGLE
Tools Batch Compile
Tools Device Manager
Tools Graphic Converter
Tools LCD Designer
Tools LIB Manager
Tools PDF Download
Tools Plugin Manager
Tools Resource Editor
Tools Terminal Emulator
TRIM
- U -
UCASE
UDP
UDPREAD
UDPWRITE
UDPWRITESTR
Updates
UPPERLINE
USB162
USBASP
USB-ISP Programmer
Using the 1 WIRE protocol
Using the I2C protocol
Using the SPI protocol
USING the UART
- V -
VAL
VARPTR
VER
VERSION
View Events
View Info Panel
View PinOut Vieewer
View Project Explorer
View Project Manager
View Properties
View Search Result
View Split View
- W -
WAIT
WAITKEY
WAITMS
WAITUS
WEND
WHILE
WHILE-WEND
Window Arrange Icons
Window Maximize All
Window Minimize All
Window next window
window previous window
Window Tile horizontally
Window tile vertically
Windows Cascade
WORD
WRITE
WRITEEEPROM
- X -
X10DETECT
X10SEND
XRAM
XRAM CF-Interface for simulation
