Adding SRAM 4-port Non Multiplexed
Top  Previous  Next
The following information was contributed by Juergen Bitzer.
Adding sram 4port non multiplexed
The EBI allows to use an SRAM in 4-port non multiplexed mode. This means that you need little parts but you loose 4 ports.
$regfile = "xm128a1def.dat"
$crystal = 32000000
$hwstack = &H32
$swstack = &H32
$framesize = &H32
$xramstart = &H100000
$xramsize = &H080000
' CPU:
' ATXMEGA128A1U-AU         : 2,23/100 Mouser  Muss -->A1U-AU<-- sein !!!
' ATXMEGA64A1U-AU
' SRam:
' 512 KB AS6C4008-55PCN    : SRAM 4MB   2.7V-5.5V, 512KX8, PDIP32
' 512 KB AS6C4008-55SIN    : SRAM 4MB   2.7V-5.5V, 512KX8, SOP32
' #### Four Port SRAM ####
' MODE SRAM 4Port direkt
' PortH.0 - Pin 55   /WR
' PortH.1 - Pin 56   /RD
' PortE.4 - Pin 39   /CS0 / A16 -> CS0: SRAM 512 KB
' PortE.5 - Pin 40   /CS1 / A17 -> CS1: unbenutzt
' PortE.6 - Pin 41   /CS2 / A18 -> CS2: unbenutzt
' PortE.7 - Pin 42   /CS3 / A19 -> CS3: unbenutzt
' PortJ.0 - Pin 65   D0   -> SRam
' PortJ.1 - Pin 66   D1   -> SRam
' PortJ.2 - Pin 67   D2   -> SRam
' PortJ.3 - Pin 68   D3   -> SRam
' PortJ.4 - Pin 69   D4   -> SRam
' PortJ.5 - Pin 70   D5   -> SRam
' PortJ.6 - Pin 71   D6   -> SRam
' PortJ.7 - Pin 72   D7   -> SRam
' PortK.0 - Pin 75   A0   -> SRam
' PortK.1 - Pin 76   A1   -> SRam
' PortK.2 - Pin 77   A2   -> SRam
' PortK.3 - Pin 78   A3   -> SRam
' PortK.4 - Pin 79   A4   -> SRam
' PortK.5 - Pin 80   A5   -> SRam
' PortK.6 - Pin 81   A6   -> SRam
' PortK.7 - Pin 82   A7   -> SRam
' PortF.0 - Pin 45   A8   -> SRam
' PortF.1 - Pin 46   A9   -> SRam
' PortF.2 - Pin 47   A10  -> SRam
' PortF.3 - Pin 48   A11  -> SRam
' PortF.4 - Pin 49   A12  -> SRam
' PortF.5 - Pin 40   A13  -> SRam
' PortF.6 - Pin 41   A14  -> SRam
' PortF.7 - Pin 42   A15  -> SRam
' PortH.2 - Pin 57   A16  -> SRam
' PortH.3 - Pin 58   A17  -> SRam
' PortH.4 - Pin 59   A18  -> SRam
' PortH.5 - Pin 60   A19 - unbenutzt
' PortH.6 - Pin 61   A20 - unbenutzt
' PortH.7 - Pin 62   A21 - unbenutzt
'----------generate a 32 MHz system clock by use of the PLL (2MHz * 23 = 46MHz)
  Config Osc = Disabled , Extosc = Enabled
  'Set the Multiplication factor and select the clock Reference for the PLL
  'Osc_pllctrl = &B00_0_10100                                 '2MHz clock Source and Multiplication factor = 23
  '                00        : 2 MHz internal OSC
  '                01        : Reerved
  '                10        : 32 MHz internal OSC
  '                11        : External Clock Source
  '                   1      : 0=PLL-Output devided by 1 |1=PLL-Output devided by 2
  '                     xxxxx: Multiplikation of PLL 1-31
  Osc_pllctrl = &B11_0_01000 : Const Mhz = 32             ' 32 MHz
  'enable PLL
  Set Osc_ctrl.4                                           'PLL enable
  'configure the systemclock
  Config Sysclock = Pll                                   'use PLL
  Config Com1 = 115200 , Mode = Asynchroneous , Parity = None , Stopbits = 1 , Databits = 8
  Open "com1:" For Binary As #1
  ' Termninal initialisieren
  Printbin #1 , &H1B ; &H5B ; &H30 ; &H6D                 ' All attributes off(normal)
  Printbin #1 , &H1B ; &H5B ; &H32 ; &H4A                 ' Bildschirm löschen
  Printbin #1 , &H1B ; &H5B ; &H48 ;                       ' Cursor Home
  Printbin #1 , &H1B ; &H5B ; &H3F ; &H32 ; &H35 ; &H68 ; ' Cursor an
  ' Einstellungen externer Speicher
  ' Alle EBI-Ports müssen auf OUTPUT
  ' ALLE Ports, die ATKIV-LOW sind müssen auf 1 gesetzt werden !!!
  ' ALLE Ports, die ATKIV-HIGH sind müssen auf 0 gesetzt werden !!!
  Print #1 , "Config Ports for external Adress / Data-Bus with no ALE... ";
  Portj_dirset = &B1111_1111 : Portj = &B0000_0000         ' D0:7
  Portj_pin0ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin1ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin2ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin3ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin4ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin5ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin6ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portj_pin7ctrl = &B0_0_000_000                           'Totem (PushPull)
  Portk_dirset = &B1111_1111 : Portk = &B1111_1111         ' A0:7
  Portk_pin0ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin1ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin2ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin3ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin4ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin5ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin6ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portk_pin7ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
'  PortX_pinYctrl = &B0_0_001_000 : X= Port A...   Y= Bit Nr. 0-7
  '                  X          :7  : 0= SlewRate normal, 1= SlewRate limited
  '                    X        :6  : 0= IO normal, 1= IO inverted
  '                      XXX    :5:3: 000 = Totem (PushPull)
  '                      XXX    :5:3: 001 = Totem + Buskeeper
  '                      XXX    :5:3: 010 = Totem + Pulldown on Input
  '                      XXX    :5:3: 011 = Totem + PullUp on Input
  '                      XXX    :5:3: 100 = Wired or
  '                      XXX    :5:3: 101 = Wired and
  '                      XXX    :5:3: 110 = Wired Or + PullDown
  '                      XXX    :5:3: 111 = Wired And + PullUp
  '                          XXX:2:0: 000 = Both edges trigger port Interrupts / Events
  '                          XXX:2:0: 001 = Rising edge trigger port Interrupts / Events
  '                          XXX:2:0: 010 = Falling edge trigger port Interrupts / Events
  '                          XXX:2:0: 011 = Low Level trigger port Interrupts / Events
  '                          XXX:2:0: 100 = Reserved
  '                          XXX:2:0: 101 = Reserved
  '                          XXX:2:0: 110 = Reserved
  '                          XXX:2:0: 111 = Input Buffer Disabled (Only Port A to F) for use with ADC or AC
  Portf_dirset = &B1111_1111 : Portf = &B1111_1111         ' A8:15
  Portf_pin0ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin1ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin2ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin3ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin4ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin5ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin6ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Portf_pin7ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_dirset = &B1111_1111 : Porth = &B1111_1111         ' WR, RD , A16, A17, A18, A19, A20, A21
  Porth_pin0ctrl = &B0_0_000_000                           'Totem (PushPull)
  Porth_pin1ctrl = &B0_0_000_000                           'Totem (PushPull)
  Porth_pin2ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_pin3ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_pin4ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_pin5ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_pin6ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porth_pin7ctrl = &B0_0_001_000                           'Totem (PushPull) + Buskeeper
  Porte_dirset = &B1111_1111 : Porte = &B1111_0000         ' CS3, CS2, CS1, CS0
  Porte_pin0ctrl = &B0_0_000_000                           'Totem (PushPull) CS3
  Porte_pin1ctrl = &B0_0_000_000                           'Totem (PushPull) CS2 SRAM
  Porte_pin2ctrl = &B0_0_000_000                           'Totem (PushPull) CS1 SRAM
  Porte_pin3ctrl = &B0_0_000_000                           'Totem (PushPull) CS0 TFT
  Porte_pin4ctrl = &B0_0_000_000                           'Totem (PushPull)
  Porte_pin5ctrl = &B0_0_000_000                           'Totem (PushPull)
  Porte_pin6ctrl = &B0_0_000_000                           'Totem (PushPull)
  Porte_pin7ctrl = &B0_0_000_000                           'Totem (PushPull)
  ' EBI-OUT legt die 4 ChipSelect's auf einen anderen Port, damit die Adressleitungen
  ' A16 bis A21 auf Port-H frei wird.
  Portcfg_ebiout = &B0000_00_11
'             XXXX         : RESERVED
'               -> 00      : EBI Port3 adress output on PORT-F 0..7: SD: 4'h0, A[11:8] - SR or SR-LPC with SD on CS3: A[23:16] - SR NoAle or ALE1: A[15:8]
'                  01      : EBI Port3 adress output on PORT-E 0..7: SD: 4'h0, A[11:8] - SR or SR-LPC with SD on CS3: A[23:16] - SR NoAle or ALE1: A[15:8]
'                  10      : EBI Port3 adress output on PORT-F 4..7: SD: A[11:8]       - SR or SR-LPC with SD on CS3: A[19:16] - SR NoAle or ALE1: ---
'                  11      : EBI Port3 adress output on PORT-E 4..7: SD: A[11:8]       - SR or SR-LPC with SD on CS3: A[19:16] - SR NoAle or ALE1: ---
'                     00   : EBI CS-output on PORT-H 4..7
'                     01   : EBI CS-output on PORT-L 4..7
'                     10   : EBI CS-output on PORT-F 4..7
'                 ->  11   : EBI CS-output on PORT-E 4..7
  Ebi_ctrl = &B01_00_11_10                                 'SRAM ALE12, 3Port
'               XX         : 00: 4 Bit Data Bus
'               XX     ->  : 01: 8 Bit Data Bus
'               XX         : 10: RESERVED
'               XX         : 11: RESERVED
'                  XX  ->  : 00: LPC-Mode: ALE1
'                  XX      : 01: LPC-Mode: RESERVED
'                  XX      : 10: LPC-Mode: ALE12
'                  XX      : 11: LPC-Mode: RESERVED
'                     XX   : 00: ALE1 - Adressbyte 0 and 1 multiplexed
'                     XX   : 01: ALE2 - Adressbyte 0 and 2 multiplexed
'                     XX   : 10: ALE12- Adressbyte 0,1 and 2 multiplexed
'                 ->  XX   : 11: NOALE- No adress multiplexing
'                        XX: 00: Externer Bus disabled
'                        XX: 01: 3 Port                      Control-Bus # Data-Bus # A0:A7 und A8:A15 über ALE1 gemuxt
'                 ->     XX: 10: 4 Port
'                        XX: 11: 2 Port
  'ChipSelect0 für  512 KByte SRam
'                       xxxxxxxx xxxx----
'                 Bit: 23    bis    12          11 bis 0 nicht verwendet
  Ebi_cs0_baseaddr = &B00010000_00000000                   ' Start &H100000 = 1M
'                       00000000_00100000_00000000 = &H002000 = 8K
'                       00000000_00110000_00000000 = &H003000 = 12K
'                       00000000_01000000_00000000 = &H004000 = 16K
'                       00000000_10000000_00000000 = &H008000 = 32K
'                       00000001_00000000_00000000 = &H010000 = 64K
'                       00000010_00000000_00000000 = &H020000 = 128K
'                       00000100_00000000_00000000 = &H040000 = 256K
'                       00001000_00000000_00000000 = &H080000 = 512K
'                 ->    00010000_00000000_00000000 = &H100000 = 1M
'                       00100000_00000000_00000000 = &H800000 = 2M
'                       01000000_00000000_00000000 = &H800000 = 4M
'                       10000000_00000000_00000000 = &H800000 = 8M
  Ebi_cs0_ctrla = &B0_01011_01                             ' Size &H080000 = 512 KB
'                    X           : RESERVED
'                      XXXXX     : AdressBlockSize
'                      00000     : 256 Byte
'                      00001     : 512 Byte
'                      00010     : 1 KByte
'                      00011     : 2 KByte
'                      00100     : 4 KByte
'                      00101     : 8 KByte
'                      00110     : 16 KByte
'                      00111     : 32 KByte
'                      01000     : 64 KByte
'                      01001     : 128 KByte
'                      01010     : 256 KByte
'                 ->   01011     : 512 KByte
'                      01100     : 1 MByte
'                      01101     : 2 MByte
'                      00110     : 4 MByte
'                      01111     : 8 MByte
'                      10000     : 16 MByte
'                            XX  : ChipSelectMode
'                            00  : disabled
'                      ->    01  : Enabled for SRAM
'                            10  : Enabled for SRAM LPC (LowPinCount)
'                            11  : Enabled for SD-SRAM
  Ebi_cs0_ctrlb = &B00000_100                             ' je nach Geschwindigkeit des SRam's
'                    XXXXX       : RESERVED
'                          XXX   : Waitstates
'                          000   : 0 Waitstates
'                          001   : 1 Waitstates
'                          010   : 2 Waitstates
'                          011   : 3 Waitstates
'                      ->  100   : 4 Waitstates
'                          101   : 5 Waitstates
'                          110   : 6 Waitstates
'                          111   : 7 Waitstates
' Nun kann das externe SRam genauso wie das interne SRam angesprochen werden.
' Vorteil: erheblich schneller im Zugriff, wie DRam !!!
' So kann auch Hardware "memory-mapped" eingebunden werden
' oder ein ISA-Bus realisiert werden.
' Now you can use the external SRAM just like the internal SRAM.
' This is much faster like DRAM
' This way you can also map hardware and access registers as you would do for SRAM
