$NOINIT
$NOINIT
Top  Previous  Next
Instruct the compiler to generate code without initialization code.
$NOINIT
$NOINIT is only needed in rare situations. It will instruct the compiler not to add initialization code. But that means that you need to write your own code then.
$NOINIT was added in order to support boot loaders. But the new $LOADER directive can better be used as it does not require special ASM knowledge.
$LOADER
