$MAP
Top  Previous  Next
Will generate label info in the report.
$MAP
The $MAP directive will put an entry for each line number with the address into the report file. This info can be used for debugging purposes with other tools.
$MAP
The report file will not contain the following section :
Code map
Line                                   Address(hex)
1                                     0
9                                     36
26                                    39
30                                    3B
31                                    3E
32                                    48
33                                    4B
36                                    50
37                                    56
42                                    5B
43                                    6C
44                                    7D
45                                    80
46                                    81
