$BGF
Top  Previous  Next
Includes a BASCOM Graphic File.
$BGF "file"
file
The file name of the BGF file to include.
Use SHOWPIC to display the BGF file. $BGF only task is to store the picture into the compressed BASCOM Graphics Format(BGF).
SHOWPIC , PSET , CONFIG GRAPHLCD
'                     (c) 1995-2020 MCS Electronics
'                 T6963C graphic display support demo
'The connections of the LCD used in this demo
'        LCD pin           Connected to
'        1        GND              GND
'        2          GND              GND
'        3          +5V              +5V
'        4          -9V              -9V potmeter
'        5          /WR              PORTC.0
'        6          /RD              PORTC.1
'        7          /CE              PORTC.2
'        8          C/D              PORTC.3
'        9          NC                not
'        10          RESET            PORTC.4conneted
'        11-18        D0-D7            PA
'        19          FS                PORTC.5
'        20        NC                not connected
$crystal = 8000000
'First we define that we use a graphic LCD
Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 2 , Cd = 3 , Wr = 0 , _
Rd = 1 , Reset = 4 , Fs = 5 , Mode = 8
' The dataport is the portname that is connected to the data lines of the LCD
' The controlport is the portname which pins are used to control the lcd
' CE, CD etc. are the pin number of the CONTROLPORT.
' For example CE =2 because it is connected to PORTC.2
' mode 8 gives 240 / 8 = 30 columns , mode=6 gives 240 / 6 = 40 columns
' Dim variables (y not used)
Dim X As Byte , Y As Byte
' Clear the screen will both clear text and graph display
Cls
' Other options are :
' CLS TEXT   to clear only the text display
' CLS GRAPH  to clear only the graphical part
Cursor Off
Wait 1
' locate works like the normal LCD locate statement
' LOCATE LINE,COLUMN LINE can be 1-8 and column 0-30
Locate 1 , 1
' Show some text
Lcd "MCS Electronics"
' And some other text on line 2
Locate 2 , 1 : Lcd "T6963c support"
Locate 3 , 1 : Lcd "1234567890123456789012345678901234567890"
Wait 2
Cls Text
' draw a line using PSET X,Y, ON/OFF
' PSET on.off param is 0 to clear a pixel and any other value to turn it on
For X = 0 To 140
Pset X , 20 , 255                                              ' set the pixel
Wait 2
' Now it is time to show a picture
' SHOWPIC X,Y,label
' The label points to a label that holds the image data
Showpic 0 , 0 , Plaatje
Wait 2
Cls Text                                                   ' clear the text
' This label holds the mage data
Plaatje:
' $BGF will put the bitmap into the program at this location
$bgf "mcs.bgf"
' You could insert other picture data here
